Just blew my radiator at work last night.... How long does it take to take out the old radiator and install a civic/ebay one. Anyone recommend it? Or just stay with the stock huge radiator?
Stay with stock. Honda engines are small, non turbo, aluminum and open deck so it doesn't need much to cool down and doesn't create much heat. 4g63 engine is cast block, close decked, small coolant holes, and turbo. You definitely need a bigger radiator and bigger front opening to cool this beast down
Quoting Xcelerate:
people here and DSM owners are running civic Radiators for space with no issues.
So from what I have read I buy a radiator and 14 inch fan, Drill holes in the support, Get rubber grommets when I can, and irregardless if I connect the sensor it will work? Just have the fan on 100% of the time.
Unless you absolutely need the space, why install a Civic radiator? Stock radiators for our application can even be found in stock in my podunk town, so they're not hard to source, and they're fairly cheap to boot.
Stay with the stock one! The Civic one holds more....Maybe, but it has less surface area to cool it down, so the capacity improvement really isn't!!!! Would you take a piece of cardboard and cover half of your stock radiator and expect it to cool the same? Keep it stock.
Quoting MegaSuiter:
Thought it would be cheaper and easier to work with, plus I have read about cars running 15 degrees cooler!
All depends on your set up. Are you running a FMIC? Do you still have the AC condenser? I had both and my temps were higher than what I would of liked them to be. This was around the fall season too...I could only imagine what the temps would of been in the hot summer months. If you are set on a civic radiator, make sure you get the highest rated cfm fan that can fit(14" might be the limit).
No AC no big fmic, so I think it will be fine. With a 14 inch fan I don't think the surface area would matter than much. Plus plenty of people are running them with no problems.
Your car shouldn't be running 15 degrees cooler due to a radiator change. Temperature is controlled by the thermostat, and running that cool will keep the ECU in "warmup" mode all the time anyway. There is no benefit.
FWIW, in 1051 I have about the biggest intercooler you can fit, and I still have AC. All on the stock radiator. Driving the car around the summer it's just fine, and it gets into the upper 90's, lower triple digits for a month here in Eastern WA.
