Catch can setup
Kenny_Kline
Seekonk, MA
I am running a blow thru setup (GM MAF) and I have a solid intake with no way to tap off intake , not that I would anyways.
I was going to eliminate the PCV valve and run 2 lines off the valve cover into this:
Would this do the job?
kenny, that is fine.. that will be how i do it also. Route the pcv and breather from the valve cover into the can and you should be good to go.
good look bro, i figured you would remove the pcv. Ive seen bungs put on the vc so you can run some nice AN fittings.
Kenny_Kline
Seekonk, MA
Do AN fitting make your car go faster? If not, rubber will work just fine.
/ubbthreads/images/graemlins/wink.gif
