carrier bearing/bushing
Gvr41415
Dallas Texas
where can i find the tw0 drive shaft carrier bearings for under $100? and do the u-joints need to be removed for install??
transparentdsm
Cherry Hill, NJ
you wont... 1 carrier bearing is 85 dollars. unless you find someone who is basically throwing them away and if your going to replace those you should replace everything. here is a link to a how to click and here is a link to a full rebuild kit at a good price click you may think its a little expensive since you were aiming in the 100$ range but i see that being very implausible.
Terry Posten
Davenport, Iowa USA
Yes, kit comes with all parts needed to replace everything with new except for the shafts and lobro joint (just re-grease that part).
And yes, you have to pop all the u-joints off to get the bearings on.
Just make sure you mark the shafts to the other shaft before removal so you put it back exactly the same orientation or you may get vibration at speed. And be very careful with the body pan studs that the bearings mount to. Use proper liquid wrench to treat the threads before removal of nuts and use anti-seize when reassembly. If you break a stud, you will not be happy.
kooter
carpentersville, IL
I get to say it again.
I am getting ready to do the same thing. just waiting on my two jaw puller. It needs to be at least 7 inches I would say.
But
youtube video
this is the first of several driveshaft 101, 102, 103 104.
I have watched it like 20 times.
Jafro makes it look so easy. Because it really is.
At least with the right tools.
