I'm sure lots of places do a kit of some sorts, so it is probably worth shopping around. FFWD Connection does a kit
here? At $555.00 it is pretty expensive but it does include a filter, modified fuel rail (with integrated AFPR), mounting clips/brackets and all the required hose and fittings.
Remember that depending upon how much of the hard line you are intending to replace you are either going to need an aftermarket filter or fittings to mate the OEM filter with the -AN fittings. Same goes with the fuel rail and fuel pump assembly. If you are upgrading your fuel system you will need an AFPR as well and more fittings to install that. Anyway you look at it, it isn't going to be cheap but I am sure you can do better than $555.00.
It really depends upon whether you want true plug and play or if you are willing to shop around and get extra fittings/adapters etc to make it work and save yourself a few bucks here and there.
