Kenny_Kline
I am using ARP head studs, main studs, and rod bolts. I am putting the ARP rod bolts in a set of 1G rods. I dropped off the rods at the machine shop and they told me they need the rod bolts to put in so they can bore the rod (big end) to make sure its circle after swaaping the rod bolts as it wont be aligned. I brought up that I am doing main studs too and they said its the same process for the crank end caps too and that they would need the block. I am just doing a rering and new bearings on the bottom end and am all set with bothering machining the block to fit some main studs. I brought this issue up to a few other guys who know the 4G63 specifics and they said that its true what the machine shop said about the rods but not about the main studs. They said the 4G63 main caps dont have alignment issues when swapping the studs as they studs fit perfectly in there. No way to shift around. It only goes on one way. I heard this from a few guys who rebuild these motors and said they are 110% sure the main studs can just be swapped but the rod bolts cant be although people do the rod bolts with no machine work and some get lucky, some dont.
Now I am thinking of leaving the main studs alone even though the guys said you can do it and you wont have problems but the machine shop are the pros so im not sure now...
Discuss
Discuss
