Anyone install a AEM UEGO with the dsm link yet?
turbophein
mass
i am in the process right not, but i want to tap into a 0-5v source that doesn't require a buffer circuit. anyone do this? also has anyone installed the AEM sensor in the stock o2 housing location? i know the dsm link can disable the stock sensor.
iLLeffeKt vr-4
NYC
You have to use a buffer and installing it in the stock o2 sensor location will significantly reduce the lifespan of the sensor. AEM recommends that you mount it at least 18" from the exhaust port. If you plan on using race gas or run at high rpm for extended amount of time then do at least 36" from the exhaust port.
I have never used a aem, but i have heard they are not accurate . I have the lm-1 and like it alot... just food for thought...
Gage
