AN fittings for turbo return?
Brunoboy
San Bruno,CA Home of SFO
Can someone tell me which ones I need to replace the whole oil return line from the turbo to the Oil Pan. I think the line is bad and I am also tired of replacing gaskets because it always leaks at the oil pan, Thanks
-Shane
TylerAdamson
Iowa City, Iowa
Here is what you want. Just click on 14b/16g in the drop down menu. I'd also recommend getting the weld fitting for the oil pan to help eliminate leaks at the pan.
TylerAdamson
Iowa City, Iowa
Yes a weld fitting. Its an option in their kit. It would eliminate any bolts/gaskets on the oil pan side of the return line. You would have the bolt holes on the oil pan welded shut and then the an weld fitting welded over the return hole. If done properly the oil pan side should never leak.
I didn't use a weld on fitting for my car. I used the AN adapter with a new gasket and crush washers for the bolts and it hasn't leaked for over four years.
mr.mitsu
canada
I have a bunch of fittings in my FS thread /ubbthreads/images/graemlins/smile.gif
1' is plenty. I think my line is only about 6" long or so. The fittings take up a lot of the length.
