aluminum radiator brazing
dsmless
tucson,az
so my radiator has a couple pin hole leaks from the wategate rubibg up on it, (yeah me being dumbass), so I took it to a radiator shop and they said it cant be braised, so has anyone done this or tryed it out, I really dont want to buy another radiator, and I dont see a justification in running a stock on, so anyone>?
dsmless
tucson,az
never mind, its easier to cut out the fins/tubes and fill weld the holes, will post a couple pics when i can,
BoostedAWD91
Danville,Pa
i have alittle leak in my aluminum radiator as well, i am just gonna take it down to my welder and have her weld the bar closed
dsmless
tucson,az
yeah thats what I had to do the problem was that the holes were kinda in the middle so yeah we just cut out the tubes and welded it up
JNR
ca
Another option: If they're small, that radiator stop leak (the pellets) work great. I did this on my chevelle years ago on the oem (I now have a new alum. unit), after a razor blade fell onto the fan, and cut a bunch of the tubes on the radiator, causing a good leak. Put that stuff in and it held for years!
