alternator heat shield
My car doesn't have a heat shield and the external wastegate/dump are very close to the alternator.
Should I get a heat shield or fab something up? If fabbing something up, does anyone have good directions and a list of exactly what I need to buy? I have never done anything like this.
Thanks!
alansupra94
Wayne,NJ
I would recommend getting one. Our alternators really don't like heat. I mean all you really have to do is divert the hot air from the dump pipe away from the alternator.
For me this is what I plan to do.
1. Coat the exhaust manifold to reduce the heat and downpipe.
2. Wrap the downpipe.
3. Install a head shield between the alternator
From here, I would test the temperature before and after using a infrared temperature probe to see how much of a difference it makes.
Dump pipe is away from altenator. Should have clarified. Running a CF vented hood too.
Actually, my exhaust manifold has a heat shield but nothing below downstream of it does. Is anything else supposed to have a heatshield?
Do you have any plans on making the alternator heatshield? What would you make it of and how would you mount it?
Thanks
