Alternate speedo gear
teamhightower
Bellevue, WA
Hi all,
I've search, but could not find a list of alternate speedo gears for the VR-4. I know there are other gears with different ratios out there from different cars (1g, 2g, etc), but can't find a list of what ratio they are. I'd like to get taller tires for my ride and it would be nice to find a taller gear for the speedo so they match better.
Can somebody point me to such a chart?
Thanks in advance.
teamhightower
Bellevue, WA
Nope. This is a chart of the trasmission gear ratios. Not the same as the speedo gears. Searched VFAQ for the speedo gear chart before posting. Heck, I love VFAQ /ubbthreads/images/graemlins/blush.gif
For my other cars, I have charts that list what years had which speedo gear. That way you can change either the final drive ratio or the tire diameter and still get near the correct rev/mile. I was hoping somebody had already done this for the Galant.
How tall? I swapped in a gear from a 1g trans. It was used stock for up to 215/50/17 tires which are much taller. I am using 22/45/17.
belize1334
Bozeman, MT
Don't bother. Even if you run something like 225/50/17 (which is HUGE at 25.8" compared to the stock is 24.2") you're only talking about an addition ~7% to your speed. Since speedometers are only accurate to about 5% it's really not worth the effort. Think 80 mph vs. 75 mph for even a grossly oversized tire... it's just not that much of a difference.
teamhightower
Bellevue, WA
Yeah, the 1g looks like a good match.
I know I'm being anal about it. I like to TSD rally the car and the closer the better. Our cars are much better then 5% accuracy, just have to figure out where the needle got pressed on. Anyway, if I didn't rally the car I wouldn't care so much.
