***ALL GONE/SOLD*** TY
ApexHunter
Marysville, WA
ALL FREE PARTS GONE!
A/C Compressor Bracket MB568808
A/C Tensioner assembly
Rear Upper Shock Mount Boots
Headlamps
Corner lamps
Plastic battery tray liner
BS seals
Alternator bracket
Rear Speaker Grilles
SOLD ITEMS
ACT 2600 clutch kit. SOLD
Walbro 255 LPH HP fuel pump GSS342. SOLD
Custom aluminum radiator setup SOLD
Magnaflow 2.5" muffler. SOLD
Mitsubishi Genuine Parts 4g63 6 bolt 1g rod/piston combo. SOLD
Non-Turbo Water Pipe SOLD
Road Race Engineering lightened flywheel. SOLD
Mofugas 2.5" Cat-Back Exhaust, SOLD
Mofugas 2.5" Downpipe SOLD
CM Performance Exhaust SS 2.5" Off Road Pipe SOLD
Helix aluminum oil catch can. SOLD
Mitsubshi Genuine Parts crankshaft for 6 bolt 4g63. SOLD
USDM OEM Fogs. SOLD
Saab Viggen FMIC. SOLD
Magnaflow (CarSound) 94000 series 2.5" High flow cat. SOLD
Road/Race Engineering fiberglass heat extractor/hood scoop. SOLD
Rear Seats from 1991 Galant VR-4. SOLD
Revolution "5 Spoke Rally" 16x7 4x114.3 wheels, +40 offset. Tires: Falken Ziex ZE-502 tires. SOLD
1G DSM spec Eibach Pro-Kit springs and AGX struts/shocks with top hats, unknown age, missing lower shock bushing x1
$90.00 - SOLD
3x OEM Transfer Case Recall Kits(fits 6th gen GVR4 all, 90-99 DSM AWD) SOLD $25 each
Cup holder $17 shipped SOLD
USDM bumper brackets $10 ea or $15/pair SOLD
Front indicator lamps SOLD
Front indicator lamps, set #2 SOLD
TSimage
Sacramento
I just noticed that that O2 bung is welded on the TOP of that DP? How can that even be used?
ApexHunter
Marysville, WA
Quoting TSimage:
It works great right there. I was using that bung for my WBo2. The sensor sits at almost 12 o'clock, and the harness comes straight up, and eventually makes it's way into the cabin through the pass through area on the firewall.
I chose this location to prolong the life of the sensor. 12-18" downstream of the turbo, in a place where it has adequate air around it for heat dissipation, and as close to 12 o'clock as possible to avoid fouling the sensor from condensation.
