Alignment specs for street/mild performance usage?
Armitage
Herndon, VA
Hey guys, I'm finally finished with with my front end and it's time for an alignment. The Evo8 struts got new DSM shims this weekend and they're welded in place with the correct bolt hole sizes so it'll fix the "variable camber" issue. Now's the time to get an alignment.
I'm curious if anyone's got any recommended settings that are both good for normal street use but also for occasional competition including RallyX and track days. I've got camber plates in the front and I was thinking of getting a mild performance alignment for the street and then dialing in more negative camber in the front for competition. I do want to maximize my tire life because the VR-4 is my daily driver.
For the back I'm thinking keeping it close to stock. I really just want to minimize understeer and make the car rotate as easily as possible.
Any suggestions?
CP
West Simsbury, CT
Got a bigger rear swayabr yet?
I've been over -3* in front when I began to track my car and it was a little much for the street. I'd suggest going with around -2* in front, -1.5* in back (my current setup for street-only). Take it to an alignment shop that'll tune the car to your EXACT specs, not just within the "acceptable range for your car according to the computer." That means ZERO (exactly) toe at all four corners.
Armitage
Herndon, VA
Rear swaybar is from a 1g DSM. It's marginally larger than the stock bar, but I don't know how much stiffer it is.
vr4play
Cincinnati, Ohio
I am running -1.2 deg in front and -0.8 in the rear with a whiteline 22mm rear bar on my street car. The car is perfect for the street. I handles really well even with the snow tires on it, and they are wearing great.
