afr reading lean
mace
Member
pueblo, Colorado
I have a safc 2 hooked up to my car right now they guy I bought it from installed it. I'm going to get dsmlink in the near future but for now I have the safc /ubbthreads/images/graemlins/frown.gif my problem is when I have it set to the correct starting point which I figured was 0%I have a 2g maf and 550 injectors. Everything else is pretty stock. My afr gauge doesnt show anything at idle meaning its way to lean where the gauge doesnt even go that high. I richen it up on the safc to where its around 14.7 on the afr and its around 19+ on the safc I can drive it for about a day and it dies and won't start up until I go alot lower on the tune. Has anyone else had this problem and if so is there anyway you were able to fix it. If there is a similar post please direct me there. Thanks
I've had bad WB and O2 sensors do this. What are you using to measure the fuel and what are you logging with?
mace
Member
pueblo, Colorado
I have a aem wb i had it in my lancer and it seemed to work fine. It also dies a lot if I just let it idle with no throtle but after it warms up for about ten minutes its ok. Think it might be related?
