Aem wideband, need some info on ecu input
jnava
Arlington, Tx
After reading ecmlink's wiki, I keep running into this barrier. If you have an Aem, you basically have the bastard child of widebands with the link. I have a 2g maf, which I use the baro and the iat, so those two are out of the question. EGR has been blocked but that input does not support it per ecmlink. The coolant temp and front o2 is what seems to be my only options but only in open loop mode. I have V2.5 on V3 software, so 02 simulation wont work since its a v3 option. Any suggestions would be greatly appreciated.
TomN
North Port, Fl
You can clamp baro and/or iat in dsm link and use those inputs. Do you live in a area where you really need to use the actual baro or iat reading? You can always tune for where you live and still clamp them. Or just upgrade. V3 really is worth the extra money.
jnava
Arlington, Tx
okay, I was unaware of that option at this point, I live in Texas so I definitely assume that iat is vital but baro..
jnava
Arlington, Tx
Quoting grocery_getter:
upgrade to v3
I know...I know... /ubbthreads/images/graemlins/banghead.gif btw, input buffer is a good option as well.
