belize1334
I need to change something about my IC to TB coupler arrangement in order to get a little more clearance between the end-tank and the strut tower.
Basically I want to shift the whole intercooler slightly forward and outboard. Currently I'm using a n/t throttlebody and the end-tank blows straight into it with a 3"x2.75" reducer. To shift it, I'd either need a turbo throttle-body with a custom elbow (offset "S" shape), or else a fancy offset silicone coupler.
AP makes just such a coupler but it only comes in 3x3 and 3x2.4 which, talking to the rep is actually 3x2.2 since it's made for a wrx which has a 2.2" turbo inlet (claimed to be 2.4, hence the name).
So, going with the coupler plan, my options are to go back to a turbo throttlebody and get a 2.25" straight flange for it (to mate to the offset 2.2" coupler in the second link), or to adapt my n/t TB to take a 3" coupler. I'm invisioning some kind of ring spacer, either silicone or possible and aluminum ring, welded to the outside of the flange.
So here's the question, if it were you, would you try to figure out how to pinch a 3" coupler on a 2.75" flange, or would you switch to a TB with a 2.25" flange for the 2.2" coupler. Keep in mind I'm going for response, not ultimate power, so having a huge TB isn't critical.
