CarRacer
I tried to install an ACT street disk in my car this weekend using a pressure plate from an Advance Auto parts clutch kit. My Fidanza pp was too f'ed up too reuse and the holidays made it hard to locate parts in my timeframe. After install the clutch would not disengage, so I had to remove the trans again. It turns out the clutch sprung hub was rubbing on the pressure plate fingers when it tried to release. The ACT hub, which I assume is the updated version, appears to be a 1/4" thicker than the Advance disk hub. I've never read about this issue before but I assume that most use the entire ACT assembly.
