DavsR
Hello community! I've tried searching but cant find any specific direction on how to test the triggers for the AC compressor like the high and low switch or thermostat switch. I've refilled my system with 1.5lb of r12 and had to run a power line from battery to compressor in order to get it to work. It blows ice cold! My problem is the compressor only works with direct power and I don't know what steps to take in order to test the switches. I replaced all O rings, new drier, new expansion valve and I've cleaned out the evaporator (looked like a nest of dirt and carpet in there), I made sure the wire to the thermostat switch was connected along with the high/low switch. Please help me figure out why my compressor won't kick on with the AC button /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/bawling.gif
