bigandbad
Hello @ all...
I've a problem with my ABS - maybe someone has had the same and can help me...
I bought my car some month ago, and everything was fine...
The first time I run at the Autobahn it drove normally.
After some days the Autobahn was empty - and I pushed it. When I drove around 100 mph, I had to brake because a truck drove into my lane...
It felt like stepping on a brick - the pedal was hard like a stone. I tried to brake harder, but suddenly the complete car was beginning to shake, it started to lurch and I needed all 3 lanes to get it under control...
No ABS light flashed...
I tried it again - at 70, 80, 90 mph everything was okay..
At 95 mph it startet shaking again.
I disconnected the ABS ECU, the ABS light at the instrument panel was glowing, and even at 130 mph the brake system was for 100% safe.
With ABS it's quite impossible to drive.
I noticed that some wires from the sensors habe been repaired, and a previous owner added an extra cable to the relais of the ABS pump, seems the harness has a break. But up to 90 mph the ABS is fully functionable, the self testing shows no problems and no problems are in the storage...
