4g64?? Need some schooling
Vr4junkie
Some wack town in CA
Ok so I been doing some searching and seen that a few people been using 4g64 blocks with 4g63 heads
What are the Pros and cons and what goes into building a 4G64T like pistons rods etc will I need custom made ones or are they inter changeable with the 4g63
89Mirageman
Stantonsburg, NC
Some people with experience may chime in here but there are a ton of threads over on Tuners that go into great detail and list the pros and cons.
FCR
Orlando, FL
WOW /ubbthreads/images/graemlins/applause.gif A lot of good info in that article....
Vr4junkie
Ok I got another question I have a 6bolt block that spun a bearing and damaged the journals on the crank so I need a new crank I know you can use the 4g64 crank and make it a 2.3 stroker but can I use my current 1g rods or will I need custom rods and pistons /ubbthreads/images/graemlins/confused.gif
