2G fuel injector clip pigtails
gvr4ever
central Indiana
Having trouble finding these online. Anyone know of a source? My car was falling on its face over 10psi the last time I drove it. Did a boost leak test and one of the injector to intake manifold seals was missing. I wanted to update the injector plug at the same time I install new injector seals.
Imback
Suffolk,NY
I would just get generic ev1 connectors though.
gvr4ever
central Indiana
I did find those on eBay, but I'm not sure how they work. Are the plastic clip 2G style NLA?
*Edit: I found a YouTube video. I'll go ahead and order those.
gvr4ever
central Indiana
Working on it now. All the injectors have different colors, but they all have a black. Does black to go black on all the injectors?
slugsgomoo
Tacoma, WA
Since they only clip on one way, I just made sure that the left versus right was the same regardless of the color of the new pigtails.
gvr4ever
central Indiana
Thank you for the reply. My car is back together except for the injector plugs. When I first installed FIC 750cc injectors, I connected the factory pin clips from Hell while attached to the rail before installing it, but it really limits movement and good angle it install the injectors and rail together. Now, I can't find away to install the injector pin connectors now that everything else is installed. I tried searching the internet, but no good solutions. Does anyone know a good way to de-pin the wires from the factory connectors? I don't want to cut above them. Sadly, my knowledge of automotive electrical is lacking. I'm not worried about properly soldering and shrink-wrapping. Just de-pinning so I don't have to cut above the connector. Any special tools needed? I just want as much extra length as I can get.
gvr4ever
central Indiana
Or, if anyone knows a trick to installing the clips with the fuel rail installed.. Please share. Unplugged injectors is the only thing keeping my car off the road. I found a great place to store her over the winter, and it's coming down to the wire. I tried just seating the factory pins, but not pushed in, but I can't seat them on the injectors. The pins are in the way and grabbing before they are pushed in What a stupid design. I guess that's all they had in the 80s, but what a cluster.
gvr4ever
central Indiana
I wasn't able to figure out how to de-pin the factory injector connector, and I didn't want to cut the wires above the connector, so I ended up installing the PITA injector clips. She's back to running great, and no boost leak.
