acn
Today I found a 22 spline t-case with matching output shaft from a 1990 Galant GSX in the local pick n pull. Somebody had actually greased the output shaft so the splines weren't worn out even though the car had 170k! My 23 spline setup is completely worn out. If I have both the 22 spline t-case and output shaft, can I replace my 23 spline setup with no issues? I thought I had read that it was possible to do this, but I haven't found anything to verify. Are 1990 GSX t-case gear ratios the same as the VR4?
