1G vr4 fmic/rad
Hey guys ive been having a coolant over heating issue with 575. Right know she has a home made fmic and a civic half radiator. /ubbthreads/images/graemlins/banghead.gif So im trying to jump on this cheap $h!t on cregslist. So will a 1g ETS FMIC and fluidyne radiator fit? Is there a difference in the vr4 radiator support? Thanks guys happy 4th!
Short answer no!
Long answer is the 1st gens have the coolant cap on the thermostat housing and GVR4s have it on the rad. So unless you swap thermostat housings as well then it will not work.
O yeah should have said i have a 2G head and the cap is on the neck. Everything else good to go though?
BlitzVR4
Virginia Beach, VA
You can fit the radiator in our cars they just have to sit lower than the filler neck. You probably would have to fabricate some brackets.
Btw where in Chesapeake are located. I live off Centerville Rd in Virgina Beach.
On the boarder of NC off 168/Ballahack rd. I think i was supposed to pick up an exhaust for you? How much lower?
BlitzVR4
Virginia Beach, VA
I don't know about the fmic. The radiator should just be below the neck. I think the 1G radiators are a little shorter in height than our cars so it should sit a little lower. See if you can get the dimensions.
That's right. Some one already picked up the exhaust. Some guy from SOVADSM with a 1G awd. Guess he is going to cut it down to fit his car.
Im glad some one picked it up. sh*t kinda hit the fan hear. I know have speed density and cant use it cuz she decides to overheat! Thats my luck......
