1G to 2G MAF conversion help
3O3EL0VR4
Parker, CO
Hey guys, finally got all the parts I needed for the conversion.
New filter - filter plate adapter - 3.75 silicon coupler - 1G to 2G harness
And of course the 2G MAF...
After I installed everything it ran really rough. It seemed like the wastegate was opening at the stock setting (6 I think) but the turbo felt like it was still spooling to the setting on the BC (14) and eventually the pull felt like it was wandering further towards the way it was with the 1G MAF or like there was a huge boost leak (which I did check after a few test runs) I have a stock 14b stock injectors and a stock EPROM ECU.
So, I was wondering is there something else that I need to do to run a 2G MAF on a stock 1G set up?
Does the EPROM ECU prevent me from using the MAF ( I thought that is what the harness adapter is for)?
I have looked around in the How To and technical sections. I haven't been able to come up with any positive results but I know this has probably been covered multiple times. Any help pointing me in the right direction, thread, or install guide would be great. Pls help /ubbthreads/images/graemlins/banghead.gif
transparentdsm
Cherry Hill, NJ
you need a chip for the eprom that compensates for the MAF change. i have also heard of people taking the silicone out of the back of the 2g maf and adjusting the plastic screw to set it up, but thats out of my realm.
dandanger
Finland
If you're planning on any other changes in future I suggest Ostrich 2.0 click or similar. If the 2g maf is the only change then a chip is ok.
JCorbo25
Sacramento, CA
the 2G MAF flows more than the 1G MAF so you'll need to chip your ECU, do tuning (DSMLink), or run an AFC to compensate.
Many people have pared the 2G MAF with 550/560cc injectors. The increased fuel from the larger injectors 'helps' compensate for the increased air flow from the 2G MAF.
3O3EL0VR4
Parker, CO
Awesome! I was looking at getting injectors and an AFC of some sort here shortly. Thanks for the quick responses guys. I figured it had to do with the A/F tuning somehow or another lol. Any suggestions you guys have for an AFC? My brother had a apexi SAFC2 on his if I remember correctly and it ran amazingly smooth. Is there anything a little newer that anyone can recommend?
