16g ofh feed line question?
Dopeem1
Active member
Loveland co
Ok guys, ill be putting the franken-turbo(ligit mhi big 16g chra and 7cm housing, not evo3) on soon and i need to know..
1. If i run my feed line do i need a restrictor?
2. If so what size.
I have done a ton of reading and there is no definite answer...
tektic
ronkonkoma, ny
I have a Hahn 16g core. I'm not using one. Someone told me that the mhi has a built in restrictor. I'm not sure. Mine does not, but I have a very large return. I only have a hundred miles like this but everything seems fine.
Use lots of silicone in the screws for the pan return. I did mine twice and it still seeps oil.
Dopeem1
Active member
Loveland co
See i have read that the mhi big 16g also has one. Im just trying to verify that i meed nothing but the line and fitting before install. I do NOT plan on running an inline filter either.
FlyingEagle
THE Ottawa
Quoting tektic:
There are little alum crush washers that are made for this particular bolt application, available from Mitsu.
It's not talked about much, and made my first job seem like a fail, when reinstalling that pipe numberous times.
Quoting tektic:
RTFM
