Sh*t box
Specs
- Ownership Status
- Currently Own
- Year
- 1991
- Production Number
- 1177
- Mods-Power
- . Borg Warner sxe369 t4 twin scroll .91, Cx racing t4 open manifold, custom made spool valve, tial 38mm wastegate, jmf race intake manifold, fic 2150cc injectors, jmf fuel rail, magna fuel pro tuner 750 fuel pump, 10an ptfe feed line, 8an ptfe return line, deatshwerks fuel pressure regulator, 3 port boost controller, frozen boost 1200hp air to water inter cooler, frozen boost 1200hp heat exchanger, rule inter cooler water pump, custom 1g aluminum radiator, custom oil cooler with derale oil cooler and oil filter relocation, foa oil accumulator, 3inch boost activated exhaust cutout with 2.5 cat back exhaust with magnaflow muffler.
- Mods-Drivetrain
- 1990 3rd and 4th gear, 1994 2nd gear, double synchro second gear, wpc treated 1-4 gears, wpc treated center differential cross shaft and gears, custom made center differential cross shaft support, custom made lsd insert in front diff, 300m output shaft transfer case, 3.5” custom aluminum driveshaft. Quarter master 6 leg twin disk with race discs, competition clutch forged clutch fork, custom made slipper clutch valve solenoid,
- Mods-Engine
- Wiseco HD 8.5:1 pistons, scat rods, kelford 280/280 cams, kiggly race springs, kiggly hla, strait cut oil pump gears, balance shaft delete, Hyundai 1.8 cylinder head stock valves and hand ported,
- Mods-EMS/Tuning
- Ecmlink, rolling anti lag button
- Mods-Handling
- Fox racing Thailand made Evo 3 coilovers, 1g Dsm camber plates for caster change, white line racing front control arm caster correction bushings, white line racing rear sway bar, energy suspension bushings on all suspension bushings front and rear. Custom made rear active toe eliminator, Rear adjustable upper esx control arms, Nissan 240sx adjustable height bump steer correction outer tie rod ends, 1g rack and pinion, custom front sway bar links from strut to control arm, 3000gt vr4 brake calipers, mustang gt brake rotors, steel braided brake lines, hawk race pads,
- Mods-Exterior
- Jnc 17x9 28+ 4x114.3 wheel's, 255/40/17 valino pergea 08rs tires, custom wrapped hood with evo 3 style custom hood vents, wrapped smoke headlights
- Mods-Interior
- Evo 8 front and rear seats, 3000gt aux radio, personal nardi steering wheel, aem air fuel ratio gauge, glow shift oil pressure and temp gauge, 3m ceramic 15% tint all windows.
- Background/Plans
- Currently at 800hp 40psi, Plan on building an aluminum motor next and bigger turbo for more pooowwwer
