1990 GGSX
Specs
- Ownership Status
- Currently Own
- Year
- 1990
- Mods-Drivetrain
Transmission:
Galant gsx stock transmission
Act 2600 clutch
JNZ 3kgt shifter
1g shift boot
Need install:
Bronze shifter bushings
TRE stage 2 transmission
TMZ transfercase (oem rebuild)
TRE 4 bolt (oem rebuild)
Oem 4 bolt cups
Act flywheel
New clutch pedal assembly
SS clutch line
Oem shifter cables
- Mods-Engine
1991 4g63 motor (used but seals were refreshed)
Evo 3 16g (brand new)
ETS intercooler kit
Evo 8 MAS
CPME turbo back exhaust
Jeverts oil cap
Koyo radiator
Moog bushing in radiator bracket
Need install:
Short block with wiseco hd pistons and eagle rods, acl bearings
Another short block with npr pistons and stock rods
Choice between 1g and a 4g61 cylinder head
Oem timing belt kit
Oem oil pump welded bse
Oem gasket kit
Gates water pump
Fp68hta (brand new)
Fluidampr
Ffofh
Turbo smart bov
Spectre oil pan
AEM can gear
ARP l19, balancer bolt and cam gear bolts
3g lifters
Oem grey timing cover
Oem dipstick and tube
Evo 3 radiator
Zaklee cam cover
IR boost solenoid
Calan catch can
ETS, FP, or Dejon intake
Tons of oem hardware
- Mods-Handling
Suspension:
Bc coilovers
Front strut bar
White line rear sway bar
Moog ball joints x6
Oem endlinks rear
Moog endlinks front
Energy suspension control arm bushings front and rear
Epoxy painted 6 control arms
Rebuilt steering rack with
5 lug conversion
Fwd spindles
Oem wheel bearings
Need install:
Clean up rear subframe
Boostx rear bushings
Clean up 1g trailing arms
Jays rear toe eliminator
Bulfab mustache bar
True street tuning 3 piece tubular crossmember
