broxma
Typically I use the search ability, even throw in the "+" and whatnot but my issue with my primary cooling fan transcends any search results I found.
Everything is in reference to the 6 pin plug at the radiator, the main cooling fan and the temp sensor located on the radiator.
I have a 6 pin fan side harness. It is not from a GVR4 so the wire colors don't match. I have searched fan wiring and while the wisdom "just use these two wires for "x" and these two for "y"" makes sense, I am unable to wire my fan in properly due to the uniqueness of my specific harness, again, not from a GVR4. My fan side harness doesn't have a resistor, just 6 wires. I cannot confirm any of the wires by color except on the harness side of the plug. I have searched for a pin out of the specific plug but either cannot find it or my sleuthing skills are not up to par.
What would be most beneficial for me would be a "pin 1-6" review of the wires. The best way I think to arrange this would be to get the 1-6 pinout as if looking at the pins on the harness side plug with the release tab to the top. Something like this...
Looking at the pins, holding the wires..
(release tab)
(Pin 1 - xxx Pin 2 - xxx Pin 3 - xxx)
(Pin 4 - xxx Pin 5 - xxx Pin 6 - xxx)
I honestly don't care too much about the color, just the function in relationship to the location.
If anyone could manage such a feat I would be eternally grateful. Thank you.
/brox
(release tab)
/brox
