NateCrisman
1992 Galant VR4 - #139/1000
Modifications:
Engine:
Stock 6bolt oem shortblock..from a low mileage dsm.
Ported 1g head w/ Ferrea springs & Ti retainers
HKS cams: 272 Exh / 264 In
90 DSM oil cooler & filter housing
Stock HG & ARP headstuds.
Balance shafts removed.
90 water pipe
Jay Racing alternator relocation
Unorthodox aluminum crank pulley
JNZ Finishing powdercoated valve cover
Prothane engine mounts[/list]
Exhaust:
T3 tube header - XS Power
Tial MVS 38mm Vband external gate
PTE T3 .63 a/r turbine housing (ford style 5 bolt outlet with no wastegate hole)
JMFab 2.5" T3 stainless o2 housing
BR 3.5" Stainless turboback exhaust[/list]
Intake:
4" aluminum intake pipe with K&N filter
Precision SC5031 turbocharger (50trim/3"inlet/2"outlet)(T31 turbine wheel/.63 ar T3 housing)
XS Power 24" x 12" x 4" FMIC core. (inlet endtank flipped & rewelded with 2.5" cast elbow)
2.5" polished aluminum custom ic pipes
knockoff tial bov
1G DSM NT throttle body
JMFabrications intake manifold (2006 race version)
[/list]
Fuel:
NOS single fogger wet nitrous kit w/ bottle heater & blanket
750cc FIC Injectors
Denso supra fuel pump
Aeromotive FPR
-6 aeroquip pushlock fuel lines (using stock return line)
Russell -6 billet fuel filter[/list]
Electronics:
DSMap speed density software on Ostrich eprom emulator
GM 3 bar map sensor and GM Air Temp sensor.
Innovate LC-1 wideband o2 sensor w/ gauge.
AEM Tru-Boost gauge controller
Datalogger cable / Palm M130 / MMSD "speed density logger"
JMFab coil relocation bracket
Magnecore wires & NGK BPR7ES plugs[/list]
Drivetrain:
TRE Stage 2 tranny rebuild
ACT2600 PP
OEM DSM disk
Clutchmasters aluminum flywheel
SS clutch line
Welded center diff
4bolt DSM rear
5 lug DSM hubs[/list]
Suspension & Brakes:
D2 coilover suspension
ES poly bushing set
SS brake lines
Fresh stock brake pads
Slotted brake rotors
ABS, 4WS, front swaybar removed
[/list]
Interior:
Aftermarket steering wheel
1G DSM Shifter Assembly w/ leather boot
2G DSM shift knob
89 dash pad
carpet dyed black[/list]
Exterior:
Carbon Fiber hood
lightweight bumper cover brackets F&R
Exel 17x7" wheels
Kumho Ecsta 215/45/17 tires
Prime 16x7" wheels (dragstrip use)
Hoosier QTP's 26x9.5(dragstrip use)[/list]
Misc
POR15 undercoating on chassis bottom, all suspension members, and subframes.
POR15 on most engine mounts, brackets. I really went nuts with the stuff and coated anything that could rust.
[/list]
Modifications:
Engine:
90 water pipe
Exhaust:
Intake:
knockoff tial bov
[/list]
Fuel:
750cc FIC Injectors
Aeromotive FPR
Electronics:
Drivetrain:
ACT2600 PP
OEM DSM disk
SS clutch line
Welded center diff
4bolt DSM rear
ES poly bushing set
SS brake lines
[/list]
Interior:
2G DSM shift knob
89 dash pad
Exterior:
Carbon Fiber hood
Exel 17x7" wheels
Misc
[/list]
