Galant VR-4 Forums » Galant VR-4 » Newbies » Replace your ECU Capacitors or your car will explode. Srsly
turbogalant
Galant VR-4 org Post #: 34701 posted 03/15/04 04:16 PM     Remind Me!  Send Private Message   Edit Post
I wanted to stess the importance of replacing the capacitor in the ECU. The capacitors used are electrolytic capacitors which means they are acid based over a period of time and heat cycles they will expand to the point where they will become porous and will leak acid on the board. Know symptoms of this is random stalling, a fish like smell, injector(s) not working. I know there is more, maybe Jeff will be nice and chime in.
REPLACE YOUR CAPACITORS! or else you will be mad.
Edited by steveGLS (06/20/05 09:50 PM)
| | | IP: (65.177.241.119) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 34702 posted 03/15/04 04:30 PM     Remind Me!  Send Private Message   Edit Post
Post deleted by Team Ducktape
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (24.12.59.172) | Report this post to a Moderator
bob in chicago
Galant VR-4 org Post #: 34703 posted 03/15/04 05:46 PM     Remind Me!  Send Private Message   Edit Post
I've got a DSM ECU you can borrow while you send yours off to be fixed.
Edited by bob in chicago (02/18/05 06:48 AM)
| | | IP: (24.148.24.5) | Report this post to a Moderator
slvrblt
Galant VR-4 org Post #: 34704 posted 03/15/04 11:09 PM     Remind Me!  Send Private Message   Edit Post
| | | IP: (68.35.27.99) | Report this post to a Moderator
Tangent
Galant VR-4 org Post #: 34705 posted 03/15/04 11:58 PM     Remind Me!  Send Private Message   Edit Post
Bad capacitors can also cause the infamous and dreaded code 44. So change those caps, it is easier than you think.
| | | IP: (4.63.89.38) | Report this post to a Moderator
dsmsleeper
Galant VR-4 org Post #: 34706 posted 03/16/04 09:21 AM     Remind Me!  Send Private Message   Edit Post
Also, make sure that that any leakage is removed. Otherwise, you may have the same problems.
| | | IP: (63.146.62.141) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 34707 posted 03/16/04 07:45 PM     Remind Me!  Send Private Message   Edit Post
quote:
Originally posted by bob in chicago:
I've got a DSM ECU you can borrow while you send yours off to Keydiver, Incorporated, Expanded and Extended, to be tweeked.
Keydiver is no longer taking in repairs/socketing/caps replacements, sorry. I highly recommend you contact russya on this group, or Dave Mertz of DSMLink in Virginia.
Jeff
| | | IP: (68.155.180.24) | Report this post to a Moderator
MitsuDriver274
Member +
Galant VR-4 org Post #: 171745 posted 01/12/05 02:08 PM     Remind Me!  Send Private Message   Edit Post
hey jeff, do you know anyone that has a ecu test bench or something, i have a downed ecu, i replaced ic 105 and ic 107, and it still don't work. Check as much as i could static testing it. I just don't know anymore
"Its not turbo lag, its foreplay" ~Michael Rodzinski
WWU Student, Major: Vehicle Design
2003 Evolution 8 #274 <= Sold to Seamus Burke
Posts: 319 | From: Bellingham, WA | Member Since: 01/20/04 | IP: (66.13.182.2) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 171904 posted 01/12/05 08:09 PM     Remind Me!  Send Private Message   Edit Post
IC105 and IC107 are just ISC drivers, they won't kill the ECU.
Dave Mertz - Maryland
[email protected]
George Little - Rochester, NY
[email protected]
Steve Piette in Chicago:
http://simon.chi.il.us/~steve/Auto/DSM/ECURepair.html
Edited by Hertz (06/20/05 08:54 AM)
| | | IP: (65.8.250.42) | Report this post to a Moderator
946
Galant VR-4 org Post #: 187630 posted 02/26/05 08:20 PM     Remind Me!  Send Private Message   Edit Post
How about some specs on the Caps?
I agree that its very important, lets just give a little more info to the newbs if possible.
I always like to tackle a job with replacement parts already in hand.
PS Jeff is the man!
| | | IP: (24.21.213.84) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 270274 posted 10/24/05 09:33 PM     Remind Me!  Send Private Message   Edit Post
I just did an ECU that looked perfect. I removed the caps and one of them had ate through the top of the board Killing 2 runs. Took me an hour more to fix.
Just because they look good, DO NOT TRUST IT.
Please do it NOW!
1992 Galant VR4 click
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (12.217.126.121) | Report this post to a Moderator
OnefstGVR4
Galant VR-4 org Post #: 322076 posted 03/28/06 12:41 PM     Remind Me!  Send Private Message   Edit Post
Check with Jim or Martin over at www.rx4speed.com he replaced the ones i had in my talon. also check his website last time i checked he "SHIPS FOR FREE" he is in NJ
| | | IP: (152.133.7.67) | Report this post to a Moderator
Nanuke
Galant VR-4 org Post #: 330537 posted 04/21/06 10:00 AM     Remind Me!  Send Private Message   Edit Post
I used the vFaq for clear instructions and ordered the caps from Digikey. Less than $10 with shipping and handling.
vFaq instructions http://www.tmo.com/howto/ecu1g/caps.htm
| | | IP: (65.102.211.27) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 341101 posted 05/20/06 07:54 AM     Remind Me!  Send Private Message   Edit Post
you can get the caps for $5 shipped on ebay.
If you need any ecu service done, contact Terry Posten on the board (that's his name and handle). He offers socketing, recapping, and board repairs.
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (128.147.38.10) | Report this post to a Moderator
95awdtsitalon
Galant VR-4 org Post #: 574674 posted 12/09/07 10:29 PM     Remind Me!  Send Private Message   Edit Post
i never knew this.. learning something new everyday.. =] replacing mine asap..
| | | IP: (24.193.197.208) | Report this post to a Moderator
Chancellor
Galant VR-4 org Post #: 635193 posted 04/16/08 12:57 PM     Remind Me!  Send Private Message   Edit Post
Quoting Anonymous:
Dead link
| | | IP: (75.71.152.242) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 651681 posted 05/29/08 12:52 AM     Remind Me!  Send Private Message   Edit Post
PLEASE READ THIS POST, PLEASE.....
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (12.210.169.170) | Report this post to a Moderator
MrVito
Galant VR-4 org Post #: 728190 posted 11/28/08 07:54 PM     Remind Me!  Send Private Message   Edit Post
Dead links in this post, perhaps we could have a running update of who offers cap replacement services and ballpark costs, as well as a new link to the DIY page, I have no idea where to find the info, but jsut a suggestion.
| | | IP: (76.125.31.199) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 728209 posted 11/28/08 08:50 PM     Remind Me!  Send Private Message   Edit Post
This link should not die.
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (12.208.67.98) | Report this post to a Moderator
MrVito
Galant VR-4 org Post #: 728244 posted 11/29/08 12:37 AM     Remind Me!  Send Private Message   Edit Post
Awesome, thanks man, sending you a pm btw
Dbossman
Galant VR-4 org Post #: 823078 posted 08/23/09 12:57 PM     Remind Me!  Send Private Message   Edit Post
Thanks the info! Never knew of this problem!! I'll be buying mine this evening!
| | | IP: (32.147.126.173) | Report this post to a Moderator
gagesta
Galant VR-4 org Post #: 891206 posted 04/18/10 12:07 AM     Remind Me!  Send Private Message   Edit Post
hi i have 94 eterna twin trubo with a ecu problem
engine light, tracktion contol light and the 4ws light comes on
after replacing ecu due 2 jump staring incorrectly
and have prolems with cold starts never had that problem
before "stupiddly" helping a naighbour 2 jump start there vehical
any remerdiez would be very helpfull
| | | IP: (121.72.70.53) | Report this post to a Moderator
gst4
Galant VR-4 org Post #: 967236 posted 02/03/11 09:04 AM     Remind Me!  Send Private Message   Edit Post
may be a dumb question but can an audio shop replace the caps???
| | | IP: (76.172.148.41) | Report this post to a Moderator
Old Balls
425/1000
Galant VR-4 org Post #: 967392 posted 02/03/11 06:27 PM     Remind Me!  Send Private Message   Edit Post
Yes, but they most likely have never seen one of these before and may not be able to find all the little places that go bad when acid leaks. And they may not have the correct spec caps and might try and make it work with parts that are not correct of up to par for the environment the ECU sees.
Posts: 9009 | From: Davenport, Iowa USA | Member Since: 12/16/03 | IP: (173.27.92.172) | Report this post to a Moderator
ronnycordova
33/1000
Galant VR-4 org Post #: 1027561 posted 10/21/11 12:18 AM     Remind Me!  Send Private Message   Edit Post
Got this over at dsmtuners for those looking to recap
Posts: 84 | From: Muncy, PA | Member Since: 10/20/11 | IP: (174.59.23.192) | Report this post to a Moderator
Pages: 1 | 2
Rating: ****
Generated in 0.712 seconds in which 0.592 seconds were spent on a total of 14 queries. Turbo powered.
