Galant VR-4 Forums » Galant VR-4 » Newbies » 4bolt and five lug question i searched didnt find the ans
Zee
Galant VR-4 org Post #: 1248308 posted 02/09/20 04:14 AM     Remind Me!  Send Private Message   Edit Post
If I do a 4bolt subframe swap will I need to buy 1g specific coilovers for the rear... And will 1g 5lug swap works on gvr4 along with gvr4. And can I use 1g calipers front and rear on gvr4??
Thanks zee
Posts: 140 | From: NY | Member Since: 08/17/04 | IP: (68.132.118.13) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1248310 posted 02/09/20 09:30 AM     Remind Me!  Send Private Message   Edit Post
you would use VR-4 coilovers front and rear as the strut length (for the rear) and top hats (for the front) are specific to the Galant but you can always use Galant top hats on DSM front struts and you may be able to adjust DSM rear coilovers to the right height on a VR-4.
1G knuckles & calipers are the same as VR-4, the only difference are the hubs & rotors are 5 lug instead of 4 lug.
Posts: 2151 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:9880:1008:8) | Report this post to a Moderator
Zee
Galant VR-4 org Post #: 1248311 posted 02/09/20 10:02 AM     Remind Me!  Send Private Message   Edit Post
Thanks bro so now I'm gonna order gvr4 specific coilovers thanks zee
#1580/2000(JUST BREAKING IN THE NEW ENGINE):D
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1248323 posted 02/12/20 05:49 AM     Remind Me!  Send Private Message   Edit Post
Specifically 1gb (93-94) front calipers are same as USDM 91-92 GVR4s, 1ga DSMs have single piston front calipers.
Zee,
1G DSMs were built on a shortened chassis of the E3x Galants, so many of their parts eill interchange with the Galants. A DSM rear subframe is the same as the Galant's but without the 4WS components bolted to it. You really don't have to change out the subframe, just to swap diffs.
If you are still running ABS, you will need to swap the ABS rings from the galant hubs onto the DSM hubs, to retain ABS, iirc. There are several how to threads on "5 lug swap".
92 Galant VR-4 362/1000
76 Galant Hardtop
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Edited by raptorWagon (02/12/20 05:50 AM)
Posts: 2778 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (2600:387:6:80d::) | Report this post to a Moderator
Zee
Galant VR-4 org Post #: 1248328 posted 02/13/20 06:03 PM     Remind Me!  Send Private Message   Edit Post
Thanks bro I got another big problem my car most of the time runs only 3 cylinders and some time its good The guys that try to install arm ems s2 messed up the wirring bad.. Can I use the harness from said 1gb 93 awd talon and fix the harness problem
Thanks zee
Edited by Zee (02/13/20 06:04 PM)
Generated in 0.14 seconds in which 0.114 seconds were spent on a total of 14 queries. Turbo powered.
