idreamidrive
I know that the 90 idler pulley is different from the others, I forgot that my engine came from a 90 eclipse and didn't order the correct length idler pulley bolt when doing my timing belt just now. I was able to find a bolt in my parts hoard that was the correct length to MF241281, but it doesn't have a lock washer on it. The vfaq says to order MF241281 and a lock washer. Does MF241281 not come with the lock washer? I blue loctite the bolt I put in, is that good enough or should I redo my work and put a lock washer on it?
