Galant VR-4 Forums » Galant VR-4 » Newbies » Hello, early JDM ECU question
fivepointnine
Newbie
Galant VR-4 org Post #: 1242710 posted 05/26/18 10:09 PM     Remind Me!  Send Private Message   Edit Post
Hi, I just picked up a '88 JDM VR4 and want to do some mods to it (16g, 560's, etc) but obviously since it has the early dual board ECU I cannot do ECMLINK on it. Is my only option going standalone? (Like the plug and play Haltech). I have an SAFC for it, but have heard horror stories of them destroying engines, etc. Is there a more reliable piggyback option?
It already has a 3" turbo back, Profec B EBC, walbro with rewire, intake, FMIC and wideband.
Zak
1988 JDM Galant VR4
Posts: 8 | From: Savannah, GA | Member Since: 05/26/18 | IP: (61.42.178.9) | Report this post to a Moderator
Galant VR-4 org Post #: 1242712 posted 05/27/18 08:46 AM     Remind Me!  Send Private Message   Edit Post
you can swap to a usdm ecu and swap some pins around in the harness.
Posts: 1401 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.189.25.4) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1242713 posted 05/27/18 11:19 AM     Remind Me!  Send Private Message   Edit Post
As above you can swap in a USDM 91/92 ECU however you will lose the ability to control the Cyclone actuation system, unless you can reconfigure the EGR/Evap? solenoid output in DSMLink.
Better yet - you could just find the MD165808 ECU from the 90+ JDM Evolution Galant VR-4 that has a 16G turbo and 510cc injectors from factory, however you would need to find the matching MAF as it is different from the non-Evolution VR-4s. You would also have to swap a couple of pins around to go from the pre-facelift wiring config to the facelift wiring config (change happened in October '89 production date for JDM models, and from 90 to 91 model years in the US).
Posts: 2098 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:fea8:4e0:b1) | Report this post to a Moderator
fivepointnine
Newbie
Galant VR-4 org Post #: 1242717 posted 05/27/18 06:16 PM     Remind Me!  Send Private Message   Edit Post
Great, thanks for all the info! I think the jdm ecu would be preferable if I can find that specific maf which might be an issue haha.
Zak
1988 JDM Galant VR4
Posts: 8 | From: Savannah, GA | Member Since: 05/26/18 | IP: (39.7.51.175) | Report this post to a Moderator
Galant VR-4 org Post #: 1242718 posted 05/27/18 07:58 PM     Remind Me!  Send Private Message   Edit Post
Honestly a plug and play standalone is about $700. Talk to Nate at performance part out about the one he uses. Hes very happy with it. Just thinking about trying to get 30 year old JDM parts in this country to work in ways they weren't supposed to is making me cringe.
fivepointnine
Newbie
Galant VR-4 org Post #: 1242725 posted 05/28/18 05:37 PM     Remind Me!  Send Private Message   Edit Post
Do any other cars share that maf? Iím not having much luck tracking down a vr4 evo maf so far
Zak
1988 JDM Galant VR4
Posts: 8 | From: Savannah, GA | Member Since: 05/26/18 | IP: (175.223.23.165) | Report this post to a Moderator
Galant VR-4 org Post #: 1242726 posted 05/28/18 05:50 PM     Remind Me!  Send Private Message   Edit Post
The one you want is MD171249
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1242743 posted 05/30/18 08:43 AM     Remind Me!  Send Private Message   Edit Post
Fuel does halltech or motec make plug and play unit that will control the cyclone? Been thinking about going to a stand alone.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8869 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
fivepointnine
Newbie
Galant VR-4 org Post #: 1242904 posted 06/11/18 09:19 PM     Remind Me!  Send Private Message   Edit Post
So can somebody break it down newbie style to me on how to do a 91-newer ECU.
-what pins on the harness need to be switched?
-I have read that you can set the cyclone actuation within the ECM link software as something to do with the EGR program?
-I will need a 91+ socketed ECU set up for ECM link, is that it?
I would really like to go with the evo0 ECU/MAF, injectors and turbo, I can find the ECU for sale, but I cannot find the MAF used and a new one is over $700 shipped from Japan.
Zak
1988 JDM Galant VR4
Posts: 8 | From: Savannah, GA | Member Since: 05/26/18 | IP: (143.138.26.244) | Report this post to a Moderator
MX4
Member +++
Galant VR-4 org Post #: 1243032 posted 06/17/18 04:12 AM     Remind Me!  Send Private Message   Edit Post
A better option than the Evo 0 AFM is one from an Lancer Evo 1/2/3 or 2G DSM. Combine this with 510cc (or larger injectors) and a chip and you would be away. You would need a chippable ECU such as the MD165808. An older dual board, such as the MD128618 are not able to be chipped for the larger injectors or different AFM.
Mitsubishi Galant VR4
12.692 @ 107.40 mph
Posts: 760 | From: New Zealand | Member Since: 04/09/01 | IP: (122.61.177.18) | Report this post to a Moderator
fivepointnine
Newbie
Galant VR-4 org Post #: 1243036 posted 06/17/18 07:16 PM     Remind Me!  Send Private Message   Edit Post
Good call! So I would just need:
"609" maf
1g to 2g maf adapter harness
"808" or similar ECU, then get it socketed for ECMLINK (what pins need switched on the ECU harness from my early dual board?)
510 or 560 EVO injectors
And then of course take it to get a live tune on a dyno.
Am I missing anything?
Zak
1988 JDM Galant VR4
AllanL
Heal and Toe
Galant VR-4 org Post #: 1243050 posted 06/18/18 07:47 PM     Remind Me!  Send Private Message   Edit Post
you would need to get the 5808 ECU first.
the other parts will depend on the availability of the 'tuneable' ECU...
pins 6 and 14 need to be swapped when switching to later than the 8618 ECU.
Posts: 243 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
fivepointnine
Newbie
Galant VR-4 org Post #: 1243053 posted 06/18/18 09:15 PM     Remind Me!  Send Private Message   Edit Post
Thank you so much for that info!
There are actually 2 of those ECU's on eBay as we speak, my wife is going to be a little mad at me lol.
Zak
1988 JDM Galant VR4
MX4
Member +++
Galant VR-4 org Post #: 1243062 posted 06/21/18 01:58 AM     Remind Me!  Send Private Message   Edit Post
Also MD150427 or MD153695 will also work, as long as they are the Eprom version of the ECU. A quick was to check is if there is a single "E" on the part number sticker rather than an "A" which is a non-Eprom version.
12.692 @ 107.40 mph
MX4
Member +++
Galant VR-4 org Post #: 1243063 posted 06/21/18 01:59 AM     Remind Me!  Send Private Message   Edit Post
Also you dont need to go to ECMLink if you want just a basic setup. A chip can be written for the different AFM and injector. Obviously you would get the tune-ability and other features with ECM though.
12.692 @ 107.40 mph
fivepointnine
Newbie
Galant VR-4 org Post #: 1243065 posted 06/21/18 05:29 PM     Remind Me!  Send Private Message   Edit Post
Is there anyone actually still writing chips?
Zak
1988 JDM Galant VR4
MX4
Member +++
Galant VR-4 org Post #: 1243094 posted 06/23/18 05:52 PM     Remind Me!  Send Private Message   Edit Post
I do but am NZ based. I dont know of anyone using ECMLink in NZ but believe a few do in Australia.
12.692 @ 107.40 mph
Galant VR-4 org Post #: 1243100 posted 06/24/18 02:42 PM     Remind Me!  Send Private Message   Edit Post
I can write chips. Can you socket your own ecu?
RHDGvr4
Newbie
Galant VR-4 org Post #: 1243767 posted 08/20/18 04:16 AM     Remind Me!  Send Private Message   Edit Post
My car has
ecu md128618
Anybody have one extra 16in Ralliart (Dymag) magnesium wheel laying around?
Posts: 14 | From: Los Angeles,California | Member Since: 08/20/18 | IP: (47.155.91.217) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1243862 posted 08/24/18 04:24 PM     Remind Me!  Send Private Message   Edit Post
According to my records you have this ECU: "128618 1988 GVR4 JDM MT E39A E2T33372 E657 J-Spec Dual Board Eprom/Non Eprom - 195hp"
C53A 1 of the ~1500
Posts: 1586 | From: THE Ottawa | Member Since: 03/05/05 | IP: (24.212.154.69) | Report this post to a Moderator
RHDGvr4
Newbie
Galant VR-4 org Post #: 1243873 posted 08/25/18 03:29 AM     Remind Me!  Send Private Message   Edit Post
My car didn't have a ecu when I got it, it is supposed to be a group n box, bought it 20 years ago,
Posts: 14 | From: Los Angeles,California | Member Since: 08/20/18 | IP: (47.153.189.114) | Report this post to a Moderator
RHDGvr4
Newbie
Galant VR-4 org Post #: 1243874 posted 08/25/18 03:36 AM     Remind Me!  Send Private Message   Edit Post
RHDGvr4
Newbie
Galant VR-4 org Post #: 1243875 posted 08/25/18 03:36 AM     Remind Me!  Send Private Message   Edit Post
RHDGvr4
Newbie
Galant VR-4 org Post #: 1243878 posted 08/25/18 04:01 AM     Remind Me!  Send Private Message   Edit Post
Eager Beaver
Galant VR-4 org Post #: 1243996 posted 09/01/18 10:25 PM     Remind Me!  Send Private Message   Edit Post
I haven't played with the dual boards up close, but you do have an Eprom chip with the red label. Hopefully that is the chip we are all swapping out for Link/ECMLink.
C53A 1 of the ~1500
Pages: 1 | 2
3 registered and 20 anonymous users are browsing this forum.
Generated in 0.107 seconds in which 0.068 seconds were spent on a total of 14 queries. Turbo powered.
