Galant VR-4 Forums » Galant VR-4 » Newbies » Which radiator?
Which radiator?
4dr_vr4
Galant VR-4 org Post #: 1242645 posted 05/19/18 05:24 PM     Remind Me!  Send Private Message   Edit Post
It is time to replace my stocker and I'd like to replace it with an aluminum one. I have a 1g mishimoto laying around along with a 1g parts car to pull the thermo housing from.
I'd also like to keep my A/C. I have read the posts here on how to make the swap. Is there another better option that is aluminum and will allow me to keep my a/c or would you just use the 1g mishimoto and call it a day?
Being that the 1g is a bit shorter than the stock, I don't want worse cooling than I started off with. Would seem foolish.
Also, is there any all aluminum radiator out there that just bolts in and has the appropriate sensor bung at the bottom and has the correct fan mounts? I have enough stuff to tap and mount.
Edited by 4dr_vr4 (05/19/18 06:59 PM)
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.65) | Report this post to a Moderator
gvr4144
144/2000
Galant VR-4 org Post #: 1242651 posted 05/20/18 11:13 PM     Remind Me!  Send Private Message   Edit Post
If you go the 1g route you pretty much have to delete your ac, use the 1g fans and thermostat housing. With that you gain alot of room and your coolant fill point is a bit higher at the head. Also any stock replacement you find will be aluminum and much lighter.
1994 Montero sr
1997 GST Spyder- dd [email protected]
1997 GST- sold
GVR4 144/2000- race car
Posts: 170 | From: loveland Colorado | Member Since: 01/26/14 | IP: (107.242.113.6) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1242659 posted 05/21/18 04:31 PM     Remind Me!  Send Private Message   Edit Post
I did a simple Google search and found this one at Amazon. Looks like it has the place for the fan switch at the bottom. I think it checks all the boxes for what you were looking for? I will try this one when I get to that point.
web page
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (05/21/18 04:33 PM)
Posts: 49 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:8::36) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1242660 posted 05/21/18 07:32 PM     Remind Me!  Send Private Message   Edit Post
Thanks guys. You have to delete your AC to go the 1g route? Are you sure. I won't go without A/C.
The Amazon radiator looks like it has the bung but I am worried about fan spacing. That radiator is also sold on ebay and not sure if they are all the same but a quick search seems to show people having a hell of a time with Ebay GVR-4 radiators.
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (2601:5cb:c080:57) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1242661 posted 05/21/18 09:15 PM     Remind Me!  Send Private Message   Edit Post
Is it the holes for mounting the fan or something else about the fan? I use a slim spal fan and had to be creative to mount it. I couldn't imagine it would be that big of a hurdle to overcome? If you get it please do a review of it, if they made it a direct fit?
Looks like "vman911" got it to fit with slight modification. At least you can keep your ac using this one.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Edited by Eztoril (05/21/18 09:28 PM)
Posts: 49 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:8::44) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1242668 posted 05/22/18 04:19 PM     Remind Me!  Send Private Message   Edit Post
Unsure, but good find on that thread. So what is it that makes you lose A/C by using a 1g radiator? Does it have something to do with that connector on the thermostat housing for the GVR4? If so, previous owner left that harness disconnected and AC works fine.
bobbybdemented
Galant VR-4 org Post #: 1242789 posted 06/03/18 01:24 PM     Remind Me!  Send Private Message   Edit Post
I have found out that a radiator from a EVO 3 will fit the Galant VR4 with very little mod. I had to add spacers to lift the radiator about a 1/2 a inch. I used hose that I slipped over the mount. Easy and works great!
Here is a link to the one I bought on Ebay. Pretty good quality for the Price.
Picture of mine installed with a Spal fan.
Posts: 37 | From: Magnolia, Tx | Member Since: 03/27/16 | IP: (107.77.100.89) | Report this post to a Moderator
2 registered and 20 anonymous users are browsing this forum.
Generated in 0.141 seconds in which 0.106 seconds were spent on a total of 14 queries. Turbo powered.
