Galant VR-4 Forums » Galant VR-4 » Newbies » Power steering delete rear subframe rack question.
ProjectBaby530
Newbie
1367/2000
Galant VR-4 org Post #: 1241494 posted 02/03/18 03:31 PM     Remind Me!  Send Private Message   Edit Post
Can someone help me with this? I bought my GVr4 with the power steering delete started. The power steering rack has been replaced with a manual one. The pump is gone and so are the main lines to the pump. I have removed most of the lines going to the rear, now my question is... Is it possible to somehow lock the rear steering rack or do I have to swap out the rear subframe. I have one from a 1g GSX but I want to rebuild it. But I'm also trying to finish up the car as soon as possible and swap the subframes at a later time. If this has been discussed or asked already, can I get a link? I tried looking already. Thanks Im new here btw lol.
Posts: 1 | From: Yuba City | Member Since: 06/22/17 | IP: (2601:206:8180:39) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1241496 posted 02/03/18 07:36 PM     Remind Me!  Send Private Message   Edit Post
There is no need to remove the Rear Subframe from your vehicle. The only difference between a 1g GSX subframe and a gvr4 subframe are the bolt hole provisions for the gvr4 Rear Steering Rack.
You can remove the Rear Steering Rack or leave it in place.
182/1000
Posts: 1456 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2600:387:2:804::) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1241504 posted 02/04/18 01:39 AM     Remind Me!  Send Private Message   Edit Post
Remove the rear rack and install the 3sx AWS delete kit. It has adjustable arms to lock the rear trailing arms in place and a welsh plug for the diff where the pump comes out.
Can be done with subframe in car but itís not hard to remove it.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (81.236.212.197) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1241505 posted 02/04/18 02:58 AM     Remind Me!  Send Private Message   Edit Post
The Rear steering just moves the toe 1.5 degrees in either direction, the DSMs just have passive 4WS vs active like a VR4. You can either get those rod things or get the Weld in joints that are on Jay Racing I believe that will remove all the adjustment out of the arms. Literally no need to do either if you don't want to, it isn't going to hurt anything if you just remove the rack.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2714 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (2601:601:4500:52) | Report this post to a Moderator
awdslim
Newbie
Galant VR-4 org Post #: 1241560 posted 02/08/18 09:13 PM     Remind Me!  Send Private Message   Edit Post
I have a complete rear subframe from a 92 dsm that iím planning on starting to swap tomorrow night. Would it be easier to just swap parts or the entire subframe assembly?
Posts: 8 | From: Charleston, SC | Member Since: 01/15/16 | IP: (73.180.91.235) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1241562 posted 02/09/18 04:19 AM     Remind Me!  Send Private Message   Edit Post
Entire subframe if all parts are good on it. I used a Dsm subframe with a 4 bolt. All new seals, bearings, bolts, and bushings. Iím satisfied.
1099/2000 Summit white
"Do it once, Do it right."
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
Vince
1212/2000
Galant VR-4 org Post #: 1241623 posted 02/13/18 11:18 PM     Remind Me!  Send Private Message   Edit Post
So.... I guess I have had enough beer to play devils advocate, and maybe admit my stupidity on both the platform, and typing while drunk... :^p
Many threads talk about the RWS delete, and I question "why?". That I am aware, the history of the car itself shows it is a championship winning car by design, 4WS and all. Now I also know the limits of the diff and 4 bolt hubs when it comes to pushing the HP up into the crazy range, but if that area is not your goal, why delete the feature at all? Can someone explain what championships this car has won without 4WS? (lets exclude the 1/4 mile stuff).
I'm just curious why so many feel the 4WS, designed by automotive engineers has interfered with winning any championship races acknowledged by the industry?
Vince
Resurrecting Nile Black 1212/2000
Posts: 61 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (73.35.165.212) | Report this post to a Moderator
brisvr4
Oceania Distict Enforcer for the Galant VR4 Mafia
Galant VR-4 org Post #: 1241624 posted 02/14/18 12:04 AM     Remind Me!  Send Private Message   Edit Post
I think that you will find that none of the works rally cars had 4WS fitted.
Fuel will be able to 100% confirm this.
It is usually removed because it is prone to leaking as the cars age and it is easier to just remove the whole thing.
I removed mine almost 10 years ago after it leaked badly and have never had an issue with not locking anything up.
Tim
1992 Auspec
11.37 @ 131.46 - E85 goodness and stock block!
Official Australian home of the Ugh decal!
Posts: 949 | From: brisbane australia | Member Since: 02/13/04 | IP: (210.10.207.110) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1241625 posted 02/14/18 02:35 AM     Remind Me!  Send Private Message   Edit Post
Quoting Vince:
Vince
As brisvr4 stated, the old lines are prone to leaking and replacement parts have been NLA for years. Once it all starts falling apart, there is no reason to keep it anymore when parts aren't available and most would rather keep their cars running and driving.
76 Galant Coupe
94 Montero SR
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1241631 posted 02/14/18 06:31 PM     Remind Me!  Send Private Message   Edit Post
Also it is possible to keep 4WS even when switching to a stronger 4 bolt rear diff as well, you just have to put the 4 bolt differential inside the stock housing to make it all work. That's another way to do it too if you have a leak free system.
76 Galant Coupe
94 Montero SR
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.136 seconds in which 0.086 seconds were spent on a total of 14 queries. Turbo powered.
