Galant VR-4 Forums » Galant VR-4 » Newbies » Parking Brake light on all the time....fluid in Master Reservoir is full
4dr_vr4
Galant VR-4 org Post #: 1240470 posted 11/12/17 07:26 PM     Remind Me!  Send Private Message   Edit Post
The Parking Brake light has decided to come on and stay on for reasons unknown. Brake lights go on and off. Brakes work fine and master is full.
Any ideas?
Thanks.
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.9) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240475 posted 11/13/17 03:28 AM     Remind Me!  Send Private Message   Edit Post
Maybe your parking brake switch took a shit. Iíd have to check schematics but I believe that it is a normally open switch and when you pull the ebrake, the plunger releases as well and the contacts close. Iíd imagine if itís not broke, itís stuck and can be physically corrected but when in doubt ohm it out.
1099/2000 Summit white
"Do it once, Do it right."
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1240476 posted 11/13/17 06:09 AM     Remind Me!  Send Private Message   Edit Post
There should also be a brake fluid level sensor connection at the master cylinder. I think it is either a 1-wire or two wire connection.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
1992 GVR-4 148/1000. Rescue
Posts: 761 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240489 posted 11/13/17 10:11 PM     Remind Me!  Send Private Message   Edit Post
Here is the service manual schematic. I do not have my reservoir plugged in and my light does not come on. I guess you can use that as a troubleshooting tool though.
Good luck
-Garrett
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (152.51.48.1) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1240500 posted 11/15/17 07:19 AM     Remind Me!  Send Private Message   Edit Post
Check the rubber gasket under the cap of the fluid reservoir.
Shape should be like this:
If not, will make the dash brake light stay on always...just massage it to bring it back to this shape.
Edited by AllanL (11/15/17 07:22 AM)
Posts: 241 | From: NV | Member Since: 08/05/08 | IP: (74.219.52.66) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240506 posted 11/15/17 10:28 PM     Remind Me!  Send Private Message   Edit Post
How would the diaphragm make the light come on?
Not saying youíre wrong by any means.
"Just to be pedantic!"
Galant VR-4 org Post #: 1240518 posted 11/17/17 11:25 AM     Remind Me!  Send Private Message   Edit Post
the diaphragm can poke out and push down the level sensor.
Posts: 2090 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1240530 posted 11/18/17 03:48 PM     Remind Me!  Send Private Message   Edit Post
Ah, I was going to say that the Park brake light comes on when the alternator brushes/voltage is dipping because things are on the way out.
C53A 1 of the ~1500
Posts: 1556 | From: THE Ottawa | Member Since: 03/05/05 | IP: (198.84.241.108) | Report this post to a Moderator
1 registered and 52 anonymous users are browsing this forum.
Generated in 0.206 seconds in which 0.194 seconds were spent on a total of 14 queries. Turbo powered.
