Galant VR-4 Forums » Galant VR-4 » Newbies » Device bolted on intake Mano near coilpack
Nebraska
1099/2000
Galant VR-4 org Post #: 1240337 posted 11/03/17 10:27 PM     Remind Me!  Send Private Message   Edit Post
So I took the car out, running great as usual. On a pull the car died and everything ignition powered was de-energized quicker than I could blink. Surprise! IGN fuse was blown under the hood. Since I was down the street I popped in the cooling fan fuse, and when I turned the key to IGN I noticed some arcing near the coil.
Itís a small 1 wire device that in cylindrical and maybe about half an inch long. Anyways, an ignition coded wire had popped out of the pin holder in the connector. What the heck is this?
Can post pics tomorrow but at work right now.
1099/2000 Summit white
"Do it once, Do it right."
828/1000
Galant VR-4 org Post #: 1240338 posted 11/03/17 11:19 PM     Remind Me!  Send Private Message   Edit Post
I think you are talking about the noise condenser (capacitor).
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10469 | From: Michigan | Member Since: 03/05/01 | IP: (98.215.89.27) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240341 posted 11/04/17 12:07 PM     Remind Me!  Send Private Message   Edit Post
Interesting, I never noticed this before. That seems to be it. What is it for or how does it work?
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1240345 posted 11/04/17 03:47 PM     Remind Me!  Send Private Message   Edit Post
Hyundai was still using this concept a few years back as evidenced when I pulled off electronics from a yard motor being installed on a 2010 Sante Fe, and it had the same values as the condensor setup on the 1G coil pack bracket.
C53A 1 of the ~1500
Posts: 1527 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.187) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1240379 posted 11/06/17 06:20 AM     Remind Me!  Send Private Message   Edit Post
Well, it is supposed to be grounded (normally bolted to the IM) It is possible it was arching when it reached a potential ground if it was disconnected.
Thom
Posts: 680 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
828/1000
Galant VR-4 org Post #: 1240382 posted 11/06/17 11:20 AM     Remind Me!  Send Private Message   Edit Post
True what Thom said. If I recall correctly, it is bolted to the manifold with the plastic wire holder for the injector harness. If someone bolted it on top of the plastic instead of beneath, it may not be grounded properly.
Posts: 10469 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1240385 posted 11/06/17 12:59 PM     Remind Me!  Send Private Message   Edit Post
It appears the noise condenser is mounted correctly. The arcing was caused by an ignition wire bouncing off the intake manifold (shorting out.) Thanks for the replyís guys.
1 registered and 11 anonymous users are browsing this forum.
Generated in 0.037 seconds in which 0.023 seconds were spent on a total of 14 queries. Turbo powered.
