Galant VR-4 Forums » Galant VR-4 » Newbies » starion/conquest tsi engine
galantless1
Newbie
Galant VR-4 org Post #: 1237956 posted 06/13/17 05:15 PM     Remind Me!  Send Private Message   Edit Post
Does a conquest tsi or starion turbo engine fit on a galant vr4?
Posts: 2 | From: brooklyn,NY | Member Since: 06/13/17 | IP: (66.108.45.142) | Report this post to a Moderator
Galant VR-4 org Post #: 1237960 posted 06/13/17 07:06 PM     Remind Me!  Send Private Message   Edit Post
No, it's rear wheel drive.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10534 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
galantless1
Newbie
Galant VR-4 org Post #: 1237965 posted 06/13/17 08:03 PM     Remind Me!  Send Private Message   Edit Post
wasn't the starion /conquest at one time awd?
Galant VR-4 org Post #: 1237971 posted 06/14/17 05:26 AM     Remind Me!  Send Private Message   Edit Post
The transmission side of the block has a wide bolt spacing. No awd starion in the USA.
Posts: 1394 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:54ad:3) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1237972 posted 06/14/17 06:04 AM     Remind Me!  Send Private Message   Edit Post
Quoting galantless1:
No, it has always been RWD. There were very few AWD models, but they were for only rally teams.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
Posts: 739 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1237974 posted 06/14/17 06:37 AM     Remind Me!  Send Private Message   Edit Post
Also older fuel control system, turbo and engine technology. there are reasons why Starion owners upgrade to 4G63 engines.
Posts: 10534 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1237979 posted 06/14/17 08:04 AM     Remind Me!  Send Private Message   Edit Post
The Astron 4G54 engine has origins dating about ten years earlier than the 4G63 series. It's a very basic design and built too heavy, though it needs to be to cope with the harmonics of a large capacity 4-cyl engine. It is physically longer thanks to its wider bore spacing and timing chain components up front. It has been mounted transverse before in vehicles like the Chrysler K cars and the Magna in Australia, in fact the first generation Magna which is basically a 5th gen Galant (same chassis as the 6G Galant) had to be widened 2.5" in order to fit the 4G54 transversely, so there's no hope it will fit into a 6G Galant.
If I were ever to do an engine transplant to the 6G Galant, it would probably be a 6G7x series V6 as we know they already fit in the engine bay (in a 5th gen Galant).
Posts: 2079 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (99.230.38.189) | Report this post to a Moderator
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 1238006 posted 06/15/17 09:28 AM     Remind Me!  Send Private Message   Edit Post
Any particular reason you would want to swap a 4G54 into a GVR4?
The 4G63 is proven and more efficient and has much more aftermarket support to meet pretty much any realistic power goals you may have.
4G54 is a pretty strong and capable motor, but I would only swap a motor for a better motor and in this case its not.
4G63>4G54
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero SR (Winter package w/ adjustable suspension)
Posts: 2465 | From: Orlando FL | Member Since: 09/30/04 | IP: (192.234.90.30) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1238008 posted 06/15/17 09:44 AM     Remind Me!  Send Private Message   Edit Post
I have a hard time justifying my built 4g54b in my Conquest, couldn't imagine swapping it in anything else to be honest. When not if I blow it up im probably going jz+r154 or 4g63+t56.
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2302 | From: USA | Member Since: 01/07/12 | IP: (173.50.97.25) | Report this post to a Moderator
Leon_R
Galant VR-4 org Post #: 1238254 posted 06/29/17 04:00 PM     Remind Me!  Send Private Message   Edit Post
4g54 cracks heads at stock boost levels, I can't ever imagine anyone going to it...
Leon
01 VehiCROSS
93 Eagle Summit TSI AWD [email protected] (4G63 transplant)
96 Mitsu Eclipse Spyder GSX
80 Triumph TR7 GST (4G63 transplant)
Posts: 210 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (199.46.250.149) | Report this post to a Moderator
Galant VR-4 org Post #: 1238265 posted 06/30/17 12:21 PM     Remind Me!  Send Private Message   Edit Post
^^ it's luck of the draw with that. The N/A ones with a wheezy 100hp manage to crack heads too. The early Sirius 4G62/4G63 SOHC heads used to do exactly the same, especially if they were equipped with MCA-Jet valves.
Posts: 2079 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
Leon_R
Galant VR-4 org Post #: 1238709 posted 07/24/17 02:14 PM     Remind Me!  Send Private Message   Edit Post
But cracking heads aside, it is a very different engine. Lots of low end torque and NOTHING at top! I had '86 back in 1991, when I test drove my first DSM (90 GSX). It remember thinking: "This Eclipse engine so happy to rev high!". Both cars were 100% stock
Leon
01 VehiCROSS
Posts: 210 | From: Chelmsford, MA | Member Since: 08/30/11 | IP: (199.46.250.147) | Report this post to a Moderator
1 registered and 14 anonymous users are browsing this forum.
Generated in 0.222 seconds in which 0.202 seconds were spent on a total of 14 queries. Turbo powered.
