Galant VR-4 Forums » Galant VR-4 » Newbies » favorite cheap catch can?
Galant VR-4 org Post #: 1236618 posted 04/16/17 10:53 AM     Remind Me!  Send Private Message   Edit Post
I'm looking for something cheap simple and effective. I don't really want to do any modifying. I came across this and would probably replace the filter so i have two lines going to the valve cover. anyone have a better suggestion?
7 1G DSM's now a GGSX build.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (67.81.192.148) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1236625 posted 04/16/17 06:06 PM     Remind Me!  Send Private Message   Edit Post
Posts: 3430 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1236717 posted 04/21/17 02:21 PM     Remind Me!  Send Private Message   Edit Post
I run a moroso 85471 and i absolutely love the thing. Very very effective.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3507 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.88.86) | Report this post to a Moderator
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1236732 posted 04/22/17 07:18 PM     Remind Me!  Send Private Message   Edit Post
Doing tech inspection for the HMSA these past few years has caused me to re-evaluate a bit here. While i'm all for a properly baffled can, particularly on high specific output forced induction applications, it would blow your mind how many of these rich schmucks with priceless historic race cars use modified aluminum water bottles, like the kind you'd buy in the Outdoor section at Walmart, or perhaps something even more ghetto.
Granted, this is mostly on normally aspirated stuff that's decades old, and again i'm all for a properly baffled can in your case, but my point is that at the end of the day it just needs to a) not leak b) be secure c) be in a location that is easy to drain and check level and d) depending on the engine and catch can configuration, be properly baffled. I feel like you are on the right track here and could probably make your own fairly easily and economically.
Edited by ApexHunter (04/22/17 07:20 PM)
Posts: 1919 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (2602:306:3696:10) | Report this post to a Moderator
Galant VR-4 org Post #: 1236737 posted 04/23/17 07:23 AM     Remind Me!  Send Private Message   Edit Post
I got the one in the first post for $40. It looks like a nice one. I've seen other companies remarket it for as much as $180. It's design made the most sense to me out of the many cheep ones I looked at. I will be connecting the filtered port to the intake manifold and the other two to larger modified valve cover ports. It will be going on a not turbo 4g63. Even the nonturbo cars have valve cover gasket failures that cake the whole bay with oil. I'm trying to avoid that with the larger ports.
Edited by tektic (04/23/17 07:25 AM)
828/1000
Galant VR-4 org Post #: 1236764 posted 04/24/17 05:16 PM     Remind Me!  Send Private Message   Edit Post
Did you pay the $70 shipping shown in that ebay link?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-Daily driver status
91 VR4 115 Nile Black -SOLD
Posts: 10490 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1236768 posted 04/25/17 06:03 AM     Remind Me!  Send Private Message   Edit Post
With that herrendous shipping price (2 months via china-post no less) added to the price, you could have gotten THIS from JMF.
Thom
Posts: 697 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Galant VR-4 org Post #: 1236771 posted 04/25/17 01:02 PM     Remind Me!  Send Private Message   Edit Post
No, I got the same one in black for $39 shipped. Still from china though.
I ordered some hose barbs for the valve cover too. 1/4"npt x 12mm (1/2") id hose
I just shaved a valve cover and removed the baffle to clean it. I'll drill and tap for the bigger fittings today or tomorrow. Will also drill and tap for new pan head screws to hold the baffle back in and smooth the inside of the valve cover. Its a very rough cast. will post pictures when I have some progress to show.
I noticed that the bottom half was very clean but the top half was filthy. I'm pretty sure this is because the port for the pcv valve is half the diameter of the one that goes out the side to the intake. That or the pcv valve was clogged.
4-29-17 update:
Drilled taped and polished the valve cover. M3x.05 to hold the baffles in place and 1/4" npt for the stock vents. Need to finish the outside now. The 1/4" hole just fits.
I decided to shave it and it's a little rough currently. Thinking of using jbweld to fill some deep gouges. I don't think regular body filler would work out right. Would it?
Edited by tektic (04/28/17 11:38 PM)
Galant VR-4 org Post #: 1236955 posted 05/06/17 08:45 AM     Remind Me!  Send Private Message   Edit Post
So the catch can came in. It doesn't seem like its going to work the way I wanted. The side with the filter is the one with the two ports. That should be the vacuum side. But that would leave me with only one input. Also the threads are m16x1.5. Kind of hard to find fittings and impossible locally. An6 and an8 fittings are available. I'm using hose barbs so I was thinking of just retapping to 3/8" npt. My plan is to put a 3/8 npt to 3/8 hose barb in the top and t it off between the intake pipe and the manifold with a one way valve on the intake pipe side. And then run the front ports to the valve cover. Inside the can I would run rubber tubes to the bottom put some stainless pot scrubbers in there and tap the 3/8 outlet with a 1/4" sinthered filter. Only problem is getting the tube to run off the little side. I can tap a fitting on the inside too but the dipstick is cut in a bad spot for this. I can maybe tap it an then just drill a relief for the dip stick when the fittings in place. I should have just got the can I got last time. Should have known I wouldn't leave well enough alone.
Here's the ports for the valve cover. 1/2" barb fittings drilled out to fit the copper tube.
Posts: 1386 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (2607:fb90:24a9:3) | Report this post to a Moderator
JamesFoster
Infamous BMX Master
674/1000
Galant VR-4 org Post #: 1237321 posted 05/19/17 05:35 PM     Remind Me!  Send Private Message   Edit Post
this one is nice for relatively cheap. click
#674/1000 760hp/630tq street car, broken transmission at the moment.
Social: @Jamesfosterbmx
Posts: 581 | From: Moreno Valley, CA | Member Since: 10/14/08 | IP: (45.51.41.9) | Report this post to a Moderator
G
obsessed with the turds of others
486/1000
Galant VR-4 org Post #: 1237323 posted 05/19/17 06:09 PM     Remind Me!  Send Private Message   Edit Post
I like these >> click
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8815 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.1) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1237337 posted 05/20/17 09:11 AM     Remind Me!  Send Private Message   Edit Post
G,
What product have you or would you install, size wise?
I saw their product list but was wondering if there is a model that you were using; currently or in the past?
C53A 1 of the ~1500
Posts: 1534 | From: THE Ottawa | Member Since: 03/05/05 | IP: (198.84.216.149) | Report this post to a Moderator
G
486/1000
Galant VR-4 org Post #: 1237347 posted 05/20/17 05:40 PM     Remind Me!  Send Private Message   Edit Post
I have this one >> click One tank for the pcv port and one for the vc port.
www.nostalgic.co.jp
Posts: 8815 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1237361 posted 05/21/17 09:01 AM     Remind Me!  Send Private Message   Edit Post
Thank you.
C53A 1 of the ~1500
marvinmadman
136/1000
Galant VR-4 org Post #: 1237370 posted 05/21/17 03:52 PM     Remind Me!  Send Private Message   Edit Post
I come across used UPR cans on the Ford forums all the time for under that price. That's the brand I run on all my cars. Good build quality and they work.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:387:1:816::) | Report this post to a Moderator
0 registered and 35 anonymous users are browsing this forum.
Generated in 0.103 seconds in which 0.068 seconds were spent on a total of 14 queries. Turbo powered.
