Galant VR-4 Forums » Galant VR-4 » Newbies » Intercooler piping
Intercooler piping
carlzedbnz
Newbie
Galant VR-4 org Post #: 1236256 posted 04/02/17 08:50 PM     Remind Me!  Send Private Message   Edit Post
Hi All
I'm going to be running a FP black on my engine and have bought a ETS gvr4 cooler for it, just wondering if being a down firing turbo the piping is going to line up with the where it enters the Intercooler ? Any body got the same set up pics much appreciated, standard radiator also.
Thanks in advance.
Posts: 2 | From: Perth AUS | Member Since: 06/13/15 | IP: (203.176.108.10) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1236268 posted 04/03/17 09:16 AM     Remind Me!  Send Private Message   Edit Post
The ETS kit came with a stock configuration piping setup as default. Did you buy a used kit? Do you have any pics of the piping?
Ryan C.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2722 | From: Savannah, GA | Member Since: 08/30/05 | IP: (198.190.246.253) | Report this post to a Moderator
Scase90
327/2000
Galant VR-4 org Post #: 1236291 posted 04/03/17 02:48 PM     Remind Me!  Send Private Message   Edit Post
Explanation with pics...
1991 Galant VR4 327/2000
07 Srt8 Charger (Daily)
Posts: 53 | From: Saint Robert, MO | Member Since: 03/25/12 | IP: (76.2.174.98) | Report this post to a Moderator
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236304 posted 04/03/17 06:46 PM     Remind Me!  Send Private Message   Edit Post
A down firing turbo will not work with an ETS FMIC designated for a VR-4. Especially if you have radiator in stock location. You could probably make a down firing turbo work but you would literally have to cut a ton of shit out of your car.
I found the anti-lag.
Posts: 579 | From: Fresno, Califonia | Member Since: 06/11/08 | IP: (2601:201:8301:1b) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1236305 posted 04/03/17 09:16 PM     Remind Me!  Send Private Message   Edit Post
re-clock the turbo??
138/2000
Posts: 3412 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1236308 posted 04/03/17 09:42 PM     Remind Me!  Send Private Message   Edit Post
That's what I did with my 35r. I wanted to see what he has before throwing out ideas though.
Ryan C.
Posts: 2722 | From: Savannah, GA | Member Since: 08/30/05 | IP: (73.21.58.201) | Report this post to a Moderator
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236339 posted 04/04/17 10:37 PM     Remind Me!  Send Private Message   Edit Post
You made your 35r down facing with a E.T.S. FMIC for a VR-4? How did you get it to clear the front engine mount?
You probably had to make all new intercooler piping too, do your pipes run underneath the frame, how did you get them to clear the radiator fan?
Strokin4dr is right it's best to see some pics, VR-4 are tight in the front area it's not a DSM.
You can make it work but it's gonna take some fabricating.
I could be wrong it's been a while since I been under the hood of my galant.
Edited by ghostinthevr4 (04/04/17 10:46 PM)
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1236356 posted 04/05/17 05:15 AM     Remind Me!  Send Private Message   Edit Post
Re-clocked
Ryan C.
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236368 posted 04/05/17 12:07 PM     Remind Me!  Send Private Message   Edit Post
When you reclocked the turbo the compressor out let wasn't running directly into your motor mount?
I could've sworn I tried that and my mount was in the way, I do have a custom tubular manifold so that could be another reason why it didn't work.
Posts: 579 | From: Fresno, Califonia | Member Since: 06/11/08 | IP: (166.137.242.90) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1236370 posted 04/05/17 12:49 PM     Remind Me!  Send Private Message   Edit Post
Wouldn't you clock it upwards? This would put the inlet at roughly the same spot as the stock j-pipe. There should be no mounts in the way up high.
Thom
Posts: 676 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236371 posted 04/05/17 12:52 PM     Remind Me!  Send Private Message   Edit Post
That's how I did mine but the op wants a down firing turbo.
138/2000
Galant VR-4 org Post #: 1236372 posted 04/05/17 12:57 PM     Remind Me!  Send Private Message   Edit Post
^ im unsure if this is the case. from the way it sounds he might not know you can re-clock the turbo.
138/2000
1025/2000
Galant VR-4 org Post #: 1236374 posted 04/05/17 02:09 PM     Remind Me!  Send Private Message   Edit Post
^^ Agreed. That is the luxury of a turbo with no internal wastegate. Re-clock the housing to suit your needs!!!
Thom
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1236387 posted 04/05/17 08:49 PM     Remind Me!  Send Private Message   Edit Post
+2
I re-clocked it with the outlet facing up. Still running stock configuration intercooler piping.
Ryan C.
ghostinthevr4
Likes Poetry
186/2000
Galant VR-4 org Post #: 1236389 posted 04/05/17 09:48 PM     Remind Me!  Send Private Message   Edit Post
Oops I'm sorry guys I misinterpreted his op I thought he wanted it down firing, I didn't realize he wanted the compressor outlet facing upwards until I reread everyone's post.
Just re clock the turbo and you'll be golden.
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1236591 posted 04/14/17 04:57 PM     Remind Me!  Send Private Message   Edit Post
If the black is same size as green, you could use a 135 deg coupler and a section of pipe to get it in the vicinity. I think I used a 90 flush against a 45 at the other end to slide right onto the ETS IC input pipe. Also made a small heat shield where it passes near the exhaust. I removed the long vertical plate that rest against the DS radiator, and the only cut I made was to notch out the stock radiator frame right where the inside of the 90 deg coupler sits. Wish I knew a way to clock and remount the WG arm so I could go over the top to reduce the combined turns a little bit.
Posts: 1268 | From: MD | Member Since: 04/07/05 | IP: (72.83.14.88) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.047 seconds in which 0.024 seconds were spent on a total of 14 queries. Turbo powered.
