Galant VR-4 Forums » Galant VR-4 » Newbies » New guy from Mass with a 4G63 Ram 50 and now a GVR4
4g63mightymax
Galant VR-4 org Post #: 1122415 posted 05/08/13 08:49 PM     Remind Me!  Send Private Message   Edit Post
Hi,
I'm Jeremy from Massachusetts and I recently acquired a Galant VR4 project that I will probably do something interesting with, I just haven't decided what that is yet. Luckily I am not a noob to 4G63's or Mitsubishi's, so there is a fair chance that it will drive again. Before I get into that though, you may want to check out my 4G63 Dodge Ram 50.
It was recently featured in Modified Magazine, which was quite cool. There is a build thread HERE if you have a few hours to burn. If not, here are the cliff notes:
1989 Ram 50 Ext cab
4G63
Evo 8 turbo
650cc injectors
ECMlink
Montero LSD
18" escalade wheels
Dodge viper Brembos and 11" rear rotors
CTS-V 14" front rotors
Some other stuff
So - Then there is the VR4. You may recognize it as well because it has been around the block (and the entire United States!). It is 1991 #1803. The white one with the partial right hand drive swap. Sadly, it is missing the RHD door panels, console, all the HVAC stuff, parts of the dashboard, etc. So like I said, I'm not entirely sure of what I will do with it from here. The good news is that it doesn't have rust, so that is always nice. Here is what it currently looks like.
So - Anybody got any of the original parts from this thing? Old pictures of it (other than the ones in the old FS thread) or interesting history about it? I would love to know more about it.
Thanks in advance!
-Jeremy
Posts: 195 | From: MA | Member Since: 04/06/13 | IP: (174.63.118.253) | Report this post to a Moderator
Captn
Crotchbaby
Galant VR-4 org Post #: 1122419 posted 05/08/13 09:05 PM     Remind Me!  Send Private Message   Edit Post
Nice!!! I have been wanting a mighty max/ ram 50 for a while! Looks awesome!
Good luck with the galant it looks pretty clean.
Edited by Captn (05/08/13 09:06 PM)
Posts: 231 | From: Houston, Texas | Member Since: 10/02/11 | IP: (65.30.192.198) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1122428 posted 05/08/13 09:48 PM     Remind Me!  Send Private Message   Edit Post
I may be able to help with a RHD drivers side door panel and other RHD bits. Send me a PM of what you need.
Posts: 2098 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (58.87.13.5) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1122432 posted 05/08/13 10:14 PM     Remind Me!  Send Private Message   Edit Post
Better late then never >> click
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8869 | From: zompton | Member Since: 02/24/04 | IP: (98.144.74.199) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122471 posted 05/09/13 06:31 AM     Remind Me!  Send Private Message   Edit Post
Hey wow! That's me! I'm thrilled that you guys saw the article and liked it. And thanks for the welcome!
Jeremy N.
GVR4 #1803/2000
Engine Noise Podcast
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1122494 posted 05/09/13 09:29 AM     Remind Me!  Send Private Message   Edit Post
Nice MM, isnt the ctsv and escalade 6lug?
Also, I wanted to buy that rhd gvr4 shell so bad last year.
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2324 | From: USA | Member Since: 01/07/12 | IP: (66.87.132.254) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122510 posted 05/09/13 10:46 AM     Remind Me!  Send Private Message   Edit Post
Yes, the Mightymax's, Ram 50's, Escalade's, Viper, and CTS-V's are all 6-lug. Unfortunately they aren't all the same bolt pattern. The other problem was that the mightymax/Ram 50 front brake rotors bolt onto the back of the hub, and the rear came with drum brakes, so the update was a bit complicated, as you can see...
Boring the center of the front CTS-V rotors...
Drilling the new holes in the Viper rear rotors
Ta-da! CTS-V front rotor bolted to the stock hub vs. stock Ram rotor. Overkilled it slightly, I know. Looking back, I would have done it differently.
-Jeremy
Posts: 195 | From: MA | Member Since: 04/06/13 | IP: (96.39.33.2) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1122512 posted 05/09/13 10:54 AM     Remind Me!  Send Private Message   Edit Post
So I assume you couldn't hub swap with something else.
Quoting coyotes:
Posts: 2324 | From: USA | Member Since: 01/07/12 | IP: (66.87.132.8) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122526 posted 05/09/13 11:36 AM     Remind Me!  Send Private Message   Edit Post
Well, you can definitely use toyota hubs on the Mitsu trucks, and they are 5-lug. Then you need to either redrill the rear axles to match or swap a new rear end in. Once you have the 5-lug pattern, you could use the factory toyota truck brakes (basically the same size as the Mitsu's) or you could get silly and do some kind of custom brake swap like I did. I guess it just depends what you are after.
The reason that I upgraded was because I got all the Viper stuff for free on the condition that I installed it on my truck. Seemed like a good idea at the time.
Jeremy N.
GVR4 #1803/2000
5OF2k
Member ++
5/2000
Galant VR-4 org Post #: 1122545 posted 05/09/13 12:49 PM     Remind Me!  Send Private Message   Edit Post
Just read through the WHOLE thread, very awesome build man. Has my head turning, as we speak. Especially considering I saw a few on my local CL for less than a grand......
Kudos, and welcome!
-Jake
1993 Talon TSI, FPgreen DD
1957 VW Beetle Sedan Deluxe
1997 Civic EX, B18c/5lug swapped
2002 Yamaha Fz-1
Looking for another GVR4, or 5/2000...PM!
Posts: 664 | From: colorado springs, colorado | Member Since: 03/28/12 | IP: (140.32.120.188) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122558 posted 05/09/13 01:28 PM     Remind Me!  Send Private Message   Edit Post
Thanks Jake! Yeah, my 40+ page build thread is 25% actual build thread, and 75% chit chat about cats, 4G63 wiring, MPI relays, etc. Glad you enjoyed it! I'm hoping that my GVR4 can be equally entertaining. I just need to figure out which direction that I want to go in.
Jeremy N.
GVR4 #1803/2000
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1122561 posted 05/09/13 01:32 PM     Remind Me!  Send Private Message   Edit Post
What trans did you use?
Quoting coyotes:
Posts: 2324 | From: USA | Member Since: 01/07/12 | IP: (70.177.215.119) | Report this post to a Moderator
nemovr4
861/1000
Galant VR-4 org Post #: 1122565 posted 05/09/13 01:40 PM     Remind Me!  Send Private Message   Edit Post
That is cool. Great job!!
92' 861/1000
1 Owner Car (technically a 1 family car)
-ECMlink V3, 16G mitsu turbo, RC550 injectors, 264i/272e HKS Cams, 2.5 pipes, C 2-stage boost position, AEM Wideband, Ported head, port matching intake&exhaust.
Posts: 139 | From: Denver, Colorado | Member Since: 11/19/12 | IP: (12.5.10.153) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122571 posted 05/09/13 01:49 PM     Remind Me!  Send Private Message   Edit Post
Well, its a Frankenstein transmission. It is technically a "narrow block KM132" from a Mightymax/Ram 50 with a 2.0L engine....
....But it has KM132 wideblock internals
...And a starquest tail section to move the shifter rearward 3 inches (due to the 4G63 engine placement)
...And I converted it to be a hydraulic clutch by welding in a new bellhousing piece from a diesel...
I also use a 6-bolt fwd flywheel with a pilot bearing machined into the center, a 225mm clutch disc and DSM pressure plate.
MarW90GSX
Galant VR-4 org Post #: 1122572 posted 05/09/13 01:50 PM     Remind Me!  Send Private Message   Edit Post
Awesome! loved your build thread! alot of good info I have passed onto my cousin lol
1990 Galant GSX 5spd
- VR4 RS Engine/trans going in soon(60k miles)
- K-sport coils
- US spec VR4 front bumper- J-spec headlights - AMG corner lights(Depo reps)- J-spec VR4 RS hood
- 16x8 XXR 532's 20+(front) 0(rear)
- Neogen 205/40 tires
Posts: 26 | From: Jupiter, FL | Member Since: 01/02/13 | IP: (108.235.237.89) | Report this post to a Moderator
DynastyLCD
Dissapointing Member
73/1000
881/1000
Galant VR-4 org Post #: 1122700 posted 05/09/13 06:38 PM     Remind Me!  Send Private Message   Edit Post
welcome to our forum, and very nice build! i had a '91 Mighty Max... i regret ever selling it
keep up the good work, hopefully the GVR4 will be just as epic as your truck. lovin' the caddy wheels in black too, nice touch!
- Phil
'92 Galant VR4 - 881/1000 - 2.0/FPgreen daily
'92 Eagle Talon TSi - 2.3/3052/1600's/killmode.
'05 Honda TRX450r - pack-a-punched woods weapon
You call down the thunder, and i'll reap the whirlwind.
Posts: 761 | From: Harwinton, CT | Member Since: 05/12/06 | IP: (75.21.27.25) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 1122817 posted 05/10/13 10:03 AM     Remind Me!  Send Private Message   Edit Post
Jeremy! welcome. Get bored on HRCS?
-Joshua Adventure Driven Design
1991 Galant VR-4
1999 Montero "Goldi-Locker"
Posts: 5593 | From: Arizona | Member Since: 05/28/03 | IP: (24.11.254.179) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1122821 posted 05/10/13 10:17 AM     Remind Me!  Send Private Message   Edit Post
Hi Josh! Nope, I didn't get bored, I just figured now that I am a GVR4 owner, I should be a member of the official forum. I also was looking up the history of my car to try to figure out if the guy that swapped it to RHD is actually a member here (doesn't seem to be?). I enjoy knowing the history of the cars that I own, and that swap is a big part of this car's history. It's probably the only reason this car has survived as long as it has.
Jeremy N.
GVR4 #1803/2000
Boos929
761/1000
Galant VR-4 org Post #: 1122969 posted 05/11/13 11:47 AM     Remind Me!  Send Private Message   Edit Post
good to see another member from mass welcome and wow!!!! what a sweet truck, awesome build
1992 galant vr4 761/1000
Posts: 28 | From: Mass | Member Since: 02/17/12 | IP: (96.240.250.37) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1122986 posted 05/11/13 04:30 PM     Remind Me!  Send Private Message   Edit Post
Great looking truck build! I've always been thinking about either one of these, or a 4cyl Cummins swap into a D50. Love the custom brakes and one-off parts! Congrats!
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (67.53.50.180) | Report this post to a Moderator
4wheelsqueal
Member +
Galant VR-4 org Post #: 1123225 posted 05/13/13 10:30 AM     Remind Me!  Send Private Message   Edit Post
Should have looked at this thread earlier!! Awesome D50. AND....I used to own 1803! Wondered where this one ended up. Ok back story as far as I know. I bought it from a guy on here who lived in Florida, FCR. The back story I got from him was that it was that a local shop in Florida did the firewall swa and that's as far as it was when FCR bought it. He was moving and had to get rid of it so I bought it and had a good friend bring it up here to Wisconsin. Started looking for more rhd pieces but got fed up with working on the gvr4 platform soo much (had 5 gvr4's, 2 1g's and 2 2g's at the same time) so I sold it to a member in New York, I forget who. He had it hauled out there but got a deal on a complete rhd galant out of Canada so 1803 went up for sale again and I lost track of it from there. Until now! Hope this helps fill in some of the holes in the backstpry. Good luck with her!
1997 Eclipse GSX - sold
2004 Evo RS
1996 Eclipse Spyder AWD - sold
555/2000 NB - 286,000 miles - sold
713/1000 KG - sold
1945/2000 BG - sold
1803/2000 SW RHD - sold
1049/2000 - sold
Posts: 446 | From: Shawano,WI | Member Since: 12/06/08 | IP: (184.95.72.72) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1123268 posted 05/13/13 03:37 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the kind words everybody!
4wheelsqueal - Yes, I did some research and this car has been unfinished through many owners! The history seems to begin at the moment FCR bought it. Before that, I can't find anything about this car. I would love to know what happened to the RHD HVAC parts when it was converted, because those are kind of a major part of the dash that I would love to have. I also noticed that the tires that are on it were made in 2010, but I highly doubt that this car was on the road then. So my guess is that they came from another VR4 somewhere along the way. I'm hoping to get another pile of random parts that come with this car very soon. Once I do that, I will evaluate where I'm at and determine what I will do with it next. I think putting it back to stock form in LHD or RHD fashion will be a pricey endeavor considering nearly every nut and bolt from the trunk forward is missing, but we'll see. The body is very clean and rust-free. I'm also ambitious and have built things from less I can't wait to get started!
Jeremy N.
GVR4 #1803/2000
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1123401 posted 05/14/13 01:14 PM     Remind Me!  Send Private Message   Edit Post
Quoting 4g63mightymax:
G52 clutch disc?
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2713 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (166.147.88.18) | Report this post to a Moderator
4g63mightymax
Galant VR-4 org Post #: 1123420 posted 05/14/13 02:21 PM     Remind Me!  Send Private Message   Edit Post
The clutch disc I have was from SouthBend Clutch. I'm not sure what it was intended for, but it is the Mightymax/Ram 50 spline with a 225mm diameter. From what I have gathered over the last 7 years though, is that a 3G Eclipse 3.0L clutch disc is basically the same thing. I haven't tested it myself though, so I can't be sure.
Jeremy N.
GVR4 #1803/2000
presterone
'92 Protege VR-4
Galant VR-4 org Post #: 1123509 posted 05/14/13 07:15 PM     Remind Me!  Send Private Message   Edit Post
Hey jeremy you messaged me on newengdsm. Im going to mass this weekend if you need any parts let me know. I have the dash, steering column e.t.c a bunch of stuff you will probably need
98 BMW 328i
92 GVR-4 #221
92 GVR-4 belize green#702
Posts: 514 | From: brunswick maine | Member Since: 01/23/12 | IP: (75.68.246.100) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10
1 registered and 17 anonymous users are browsing this forum.
Generated in 0.125 seconds in which 0.071 seconds were spent on a total of 14 queries. Turbo powered.
