WOT rattling
James
Port richey Florida
I don't expect a specific answer for this, but its worth a try I guess.
Under WOT I hear a type of... Rattle noise... From the driver side of the engine bay. It sounds almost as if you had a big bag of marbles and were bouncing the bag around. It's only under full throttle that I hear it. Sounds like maybe from the head? Hard to tell from the drivers seat. I've investigated it, couldn't find any loose bolts or fittings or anything.
Now I do think I have a pulley getting ready to go out but I don't think the two noises are related. Under normal cruising condition with maybe 25% throttle I get a wobble sound. Goes away with more or less throttle.
MellowVR4
Milwaukee, Wi
maybe a harmonic balancer?
James
Port richey Florida
The rattle, wobble, or both?
That was my guess for the wobble. Or water pump. But I can't see how the pullies can make that chatter.
The car idles fine, drives fine, pulls strong. Nothing in the oil, coolant is clean.
MellowVR4
Milwaukee, Wi
when did this issue become noticable
James
Port richey Florida
I would say... After a cracked the valve cover? Two hairline cracks. I assume the notice was just sounds coming from the head and was more noticeable due to the cracks letting sound through.
I have a new valve cover and gasket now.
James
Port richey Florida
But also, prior to that I was unable to to a real pull in the car due to phantom knock and boost creep. Along with loud lifters. I fixed all of this at the same time. So the problem could have been from before but went unnoticed.
The wobble has been there since I got the car.
MellowVR4
Milwaukee, Wi
^ whats that?
James
Port richey Florida
Logger shows no knock. And like I said, it pulls hard at 18psi.
MellowVR4
Milwaukee, Wi
Axle support bearing?
James
Port richey Florida
I'll check that out on my next day off! I didn't think suspension. The sound "sounds" like its coming from higher up than that but who knows with how sound travels
5OF2k
colorado springs, colorado
Does the car still have the balance shafts??
James
Port richey Florida
Good question I've never checked. They removed all the emissions, egr, ect stuff that everyone removed so I would assume the PO did a balance shaft elimination on his rebuild. But ill double check to be sure.
I assume you are suggesting that for the wobble noise and not the chatter.
