H&R springs
I am. Click the link in my sig below.
Struc
Oconomowoc, WI
Me too. I really like the look, but is a fairly dramatic change in what I'm used to with the car. I keep hitting the bump stops. I've only driven it a few days with the new springs, though, so I may get used to it. There are some pictures in a different thread. I'll edit my post with that link.
Edit: click
KiNgMaRtY
Corona, CA
Struc: I think your struts may not be able to handle your H&R's.
I have H&R's with Koni yellow struts and feels about how my STi felt with stock suspension (as far as stiffness and control of spring)
OP: Apparently the H&R springs have to be cut in the back
SouthCaliVR4
North county San Diego
I know i cut at least one dead coil in the rear, maybe one and a half /ubbthreads/images/graemlins/dunno.gif Can't recall
H&R sports w/17x7.5 5zigen wheels & 225/45's
Oh yea, using kyb agx's.
Struc
Oconomowoc, WI
Quoting KiNgMaRtY:
I bought them used as a strut/spring combo already assembled. The struts are GR-2's.
The ride is fine - no complaints there - we just have crappy roads around here.
Mine are not cut.
Brunoboy
San Bruno,CA Home of SFO
I blew my gr2's and my AGX's, both had HnR springs, Right now Evo suspension seems the best way to go.
Launch
Texas
You guys are cutting coils from the H&Rs on koni yellows? Doesn't that effect ride quality tremendously? I thought it was completely bolt on affair.
SouthCaliVR4
Quoting Launch:
I can only speak of the h&r's with the agx's. on mine it left the car with a ton of rake. I didn't like it so i cut a couple out of the rear only & only the stacked "dead coils", there was no effect on ride quality what so ever.
KiNgMaRtY
Corona, CA
Quoting Struc:
Quoting KiNgMaRtY:
GR-2 is designed as an OEM replacement with OEM springs. I had GR-2's with H&R springs when I bought 611/1000 and the ride was horrible.
KiNgMaRtY
Corona, CA
Unless H&R changed the rear springs? Can those of you with the uncut and cut springs post a part number if possible? I know the H&R's that are on 802 are cut per prev owner and the ones on 611 who knows but I remember there being a bit of difference in how many coils. I will have to check next time I work on my buddies now 611
thats what im running and the rear definitely sits higher then the front. as for ride. i like em.
dmj
orlando FL
I had to cut one coil on my H&R's in the rear it was way to jacked up before . It sits like this now
dmj
orlando FL
I am running KYB GR2 struts front and rear. Ride is extremely smooth almost like a luxury car a little too soft for my taste though.
BluFalcon
Wichita, KS
Remember, most aftermarket struts for our cars are made for DSM's. The front spring perch on the DSM struts is actually lower than the stock GVR4 strut, so the H&R's are going to sit lower in the front than originally intended and give it that "raked" look. I ended up cutting about 3/4 of a coil out of my rear H&R's before I was happy with the way the car sat. I still think the front sits too low with the H&R's. Luckily I have a set of Ground Controls going on it when I get my car back, so I can "fix" that.
blackvr4
NJ
My galant H&Rs KYB AGXs no cut coils, have been thinking about cutting the coils, really not feelin the rake /ubbthreads/images/graemlins/frown.gif
dsm10o0
San Jose CA
My car has H&R's on KYB AGX's. The back really need to be cut.
