Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Which Evo Coilovers can be used on 91 GVR4
VR4MOE
Newbie
Galant VR-4 org Post #: 1242845 posted 06/07/18 09:13 AM     Remind Me!  Send Private Message   Edit Post
Hey Guys,
I am currently running stock 4 lug. But wish to keep it 4 lug. Can I use any Evo coil overs on my GVR4?
Posts: 5 | From: Copiague, NY | Member Since: 05/18/18 | IP: (75.127.250.178) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1242846 posted 06/07/18 10:01 AM     Remind Me!  Send Private Message   Edit Post
Yes. Just need the 3SX adapters.
I love my crazy mother!!!
Posts: 1549 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
VR4MOE
Newbie
Galant VR-4 org Post #: 1242853 posted 06/07/18 04:25 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the reply.
Would you know which Evo I can use suspension from?
Also do you have a link of this "3SX adapters" that can be purchased?
"Just to be pedantic!"
Galant VR-4 org Post #: 1242856 posted 06/08/18 07:53 AM     Remind Me!  Send Private Message   Edit Post
Evo 8/9 will need the adapters for the rear, Evo X will need the lower bush on the rear shock changed out to work.
You can get the SCE adapters direct from Supercar Engineering (where you can purchase just the rears instead of the whole set) - click
Edited by fuel (06/08/18 07:54 AM)
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (2607:fea8:4e0:b1) | Report this post to a Moderator
VR4MOE
Newbie
Galant VR-4 org Post #: 1242857 posted 06/08/18 08:56 AM     Remind Me!  Send Private Message   Edit Post
OK just to confirm that this would work on my 91 Galant VR4?
I want to confirm because it does not state the GVR4. Only vehicle mentioned is the 3000 GT VR4
Galant VR-4 org Post #: 1242858 posted 06/08/18 09:25 AM     Remind Me!  Send Private Message   Edit Post
Yes works on the Galant VR-4 (and 1st gen Diamante AWD). 3000GT/GTO and Diamante AWD share the same platform which is derived from the 6th gen Galant AWD.
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
VR4MOE
Newbie
Galant VR-4 org Post #: 1242865 posted 06/08/18 12:22 PM     Remind Me!  Send Private Message   Edit Post
AWESOME information!! Thank you
*CHEERS*
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1242874 posted 06/09/18 02:38 AM     Remind Me!  Send Private Message   Edit Post
don't you also have to run different bolts on the front lowers, and put some sort of spacers in, as the evo knuckles are thicker than 1g/gvr4?
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3652 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (75.172.23.208) | Report this post to a Moderator
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1242880 posted 06/10/18 12:15 AM     Remind Me!  Send Private Message   Edit Post
I have the rear SCE adapters direct from Supercar Engineering for the Evo shocks and springs and there is an issue with them that has been noted by others.
The 3/S has a R lower shock mount with a larger diameter taper than the GVR4. This means that if you install the tapers of the mount and adapter aligned with each other the way they were designed for, the fit will be sloppy. If the adapter is installed with tapers opposite to each other, the smaller diameter of the taper on the adapter fits closely (no slop) on the larger end of the mount closest to the trailing arm.
I can see how this would work short term, but there will be a very small amount of bearing surface between the tapered mounting stud and the reverse tapered adapter. I am afraid to run it this way as I think the white adapter bushing (feels like nylon) is going to deform and get hogged out and loose.
Edited by 467 (06/10/18 01:15 AM)
Posts: 889 | From: Fremont Ca | Member Since: 03/16/01 | IP: (24.6.21.118) | Report this post to a Moderator
slugsgomoo
461/1000
Galant VR-4 org Post #: 1242881 posted 06/10/18 04:12 AM     Remind Me!  Send Private Message   Edit Post
The best question in this thread that hasn't been asked is WHY.
Unless you already have coilovers for an Evo, why not just get Galant specific ones? If you do have a set, why not just buy the right mounts (assuming the threaded body is a standard diameter).
It's not 2004, there are options that don't involve "cobble something together"
-andrew
{witty signature}
2014 Ford Focus ST
2 registered and 7 anonymous users are browsing this forum.
Generated in 0.427 seconds in which 0.407 seconds were spent on a total of 14 queries. Turbo powered.
