Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » No injector pulse, no power on pin 102
alik
Member +
40/2000
Galant VR-4 org Post #: 1242547 posted 05/12/18 10:23 AM     Remind Me!  Send Private Message   Edit Post
the car starts, but won't run.
I've put a test light on PCM connectors, and I've got no power on 102 & 107, and no ground on 106.
Could someone confirm that the MPI relay is the culprit?
Thanks!!!
#40/2000, Nile Black
'90 Miata, waay too fast in corners
Posts: 357 | From: Boston, MA | Member Since: 08/08/06 | IP: (73.17.151.96) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1242563 posted 05/14/18 06:00 AM     Remind Me!  Send Private Message   Edit Post
106 is Chassis ground. Have you tried correcting that problem to see is the symptoms change? Pin 106 feeds the Camshaft Position Sensor ground. Also check Pin 101 as it is also ties to pin 106.
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Edited by thomcasey (05/14/18 06:05 AM)
Posts: 797 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
alik
Member +
40/2000
Galant VR-4 org Post #: 1242565 posted 05/14/18 07:20 AM     Remind Me!  Send Private Message   Edit Post
There's ground on 101, but not on 106.
Is that weird?
Posts: 357 | From: Boston, MA | Member Since: 08/08/06 | IP: (146.115.72.141) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1242568 posted 05/14/18 09:15 AM     Remind Me!  Send Private Message   Edit Post
Depending on where they interconnect, not weird at all. 27 year old harness after all.
Thom
alik
Member +
40/2000
Galant VR-4 org Post #: 1242569 posted 05/14/18 09:21 AM     Remind Me!  Send Private Message   Edit Post
So it would make sense to jump 106 to ground? Or tie it to 101?
866/1000
Galant VR-4 org Post #: 1242570 posted 05/14/18 09:29 AM     Remind Me!  Send Private Message   Edit Post
Yes. Also look at the CAS and verify the ground pin is working/good.
Thom
alik
Member +
40/2000
Galant VR-4 org Post #: 1242571 posted 05/14/18 09:31 AM     Remind Me!  Send Private Message   Edit Post
Thank you, sir!
Will do!
3 registered and 35 anonymous users are browsing this forum.
Generated in 0.268 seconds in which 0.256 seconds were spent on a total of 14 queries. Turbo powered.
