Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » What exactly is the material on the exterior roof?
Kibby
452/2000
Galant VR-4 org Post #: 1241914 posted 03/10/18 09:30 AM     Remind Me!  Send Private Message   Edit Post
Its like a thick material??? Anyways i haven't been on in quite awhile. Car is still jsb and outside forces have kept me from getting the car running again. I do however want to keep/slow things down from getting worse. Just wanted to know the best route to go. Thanks
Posts: 212 | From: Baltimore,MD | Member Since: 01/16/13 | IP: (99.203.16.34) | Report this post to a Moderator
Galant VR-4 org Post #: 1241919 posted 03/10/18 06:50 PM     Remind Me!  Send Private Message   Edit Post
Paint?
Posts: 1393 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (98.7.27.255) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1241956 posted 03/13/18 04:37 PM     Remind Me!  Send Private Message   Edit Post
^ Yep, Paint on mine too.
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) | Report this post to a Moderator
Kibby
452/2000
Galant VR-4 org Post #: 1241959 posted 03/13/18 06:21 PM     Remind Me!  Send Private Message   Edit Post
So just a really thick coat of paint? The stuff chipping off is like 1/16" thick, probably thicker.
As a rule of thumb for the Mitsubishi owner with a desire to go faster "If your car ain't broke, you are"
Posts: 212 | From: Baltimore,MD | Member Since: 01/16/13 | IP: (99.203.17.211) | Report this post to a Moderator
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1241960 posted 03/13/18 08:24 PM     Remind Me!  Send Private Message   Edit Post
Maybe you're seeing the clear coat peeling?
Done there, been that
Posts: 1269 | From: MD | Member Since: 04/07/05 | IP: (108.28.40.107) | Report this post to a Moderator
FlyingEagle
Eager Beaver
Galant VR-4 org Post #: 1241963 posted 03/13/18 10:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting Kibby:
Pics??
Sounds like plastic body filler, if it is anything other than a "skin" film coming off the paint.
C53A 1 of the ~1500
Posts: 1540 | From: THE Ottawa | Member Since: 03/05/05 | IP: (108.162.128.98) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1241964 posted 03/14/18 02:19 PM     Remind Me!  Send Private Message   Edit Post
Maybe someone repaired some hail damage, and it is body filler your seeing?
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1241970 posted 03/14/18 05:24 PM     Remind Me!  Send Private Message   Edit Post
Yeah, itís just steel with primer, base coat, and clear. If youíre seeing anything else it would have to be shoddy repair work unfortunately.
-Mark
1051
Posts: 11868 | From: Yakima, WA | Member Since: 04/29/01 | IP: (66.224.36.237) | Report this post to a Moderator
Kibby
452/2000
Galant VR-4 org Post #: 1241978 posted 03/15/18 04:26 PM     Remind Me!  Send Private Message   Edit Post
This is whats going on. About 6 inches to the left of this is the windshield
Posts: 212 | From: Baltimore,MD | Member Since: 01/16/13 | IP: (99.203.16.31) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1241980 posted 03/15/18 05:49 PM     Remind Me!  Send Private Message   Edit Post
That is a cracked and broken skim coat on the roof. My son has the same on 100/2000. Looked perfect until the PO got mad and dented the roof. Big piece broke off.
Thom
1992 GVR-4 866/1000. Ready for all of the above.
Posts: 724 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c402:59) | Report this post to a Moderator
Vince
1212/2000
Galant VR-4 org Post #: 1241986 posted 03/15/18 11:02 PM     Remind Me!  Send Private Message   Edit Post
That simply is not right........ Maybe someone filled in a missing sunroof?
Resurrecting Nile Black 1212/2000
Posts: 51 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (73.35.165.212) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1241987 posted 03/16/18 02:13 AM     Remind Me!  Send Private Message   Edit Post
^ Yep, hail or maybe sunroof removal. Regardless someone has filled it for some reason and now itís no good.
Kibby
452/2000
Galant VR-4 org Post #: 1242063 posted 03/23/18 12:32 PM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
So best route would be remove it all, do the por fix, apply a new skim coat and paint?
Posts: 212 | From: Baltimore,MD | Member Since: 01/16/13 | IP: (99.203.16.153) | Report this post to a Moderator
Galant VR-4 org Post #: 1242064 posted 03/23/18 12:56 PM     Remind Me!  Send Private Message   Edit Post
You don't really need POR if that is what you are suggesting. You will likely need some serious dent removal before removing any rust and priming/painting properly.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10527 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
0 registered and 33 anonymous users are browsing this forum.
Generated in 0.259 seconds in which 0.242 seconds were spent on a total of 14 queries. Turbo powered.
