Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Serpentine Belt Keeps Being Tossed
diambo4life
476/2000
Galant VR-4 org Post #: 1240289 posted 11/01/17 08:43 PM     Remind Me!  Send Private Message   Edit Post
I am at my wits end about this. Everything looks ok but as soon as I make a 2nd gear pull, out goes the belt. The harmonic damper is not separated and both water pump and alternator pulleys are facing the right direction. Used two different belts with the same outcome. Loosening or tightening the belt has not made a difference. What else should I look for that I am overlooking?
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (2600:8803:9001:3) | Report this post to a Moderator
Defiant
Definitely? Defiantly? wat
136/1000
Galant VR-4 org Post #: 1240290 posted 11/01/17 09:24 PM     Remind Me!  Send Private Message   Edit Post
Did you put the water pump pulley on backwards by chance?
136/1000
Posts: 164 | From: Houston, TX | Member Since: 09/07/12 | IP: (2601:2c1:8201:78) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1240300 posted 11/02/17 04:38 AM     Remind Me!  Send Private Message   Edit Post
Mitsubishi alternator in stock location?
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2754 | From: Savannah, GA | Member Since: 08/30/05 | IP: (69.245.80.109) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1240302 posted 11/02/17 07:38 AM     Remind Me!  Send Private Message   Edit Post
^ this. I have a Jay racing relocation kit on my car and the kid I got it off had the shims backwards and the belt would walkvevery time I went about 3k rpm.
138/2000
Posts: 3451 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1240307 posted 11/02/17 10:26 AM     Remind Me!  Send Private Message   Edit Post
The pulleys are oriented correctly with the dish side facing the engine. Stock AZ alternator. Stock location. Visually, there was no misalignment. I currently have it taken apart to fix a leaking crank seal.
Edited by diambo4life (11/02/17 10:27 AM)
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1240311 posted 11/02/17 12:06 PM     Remind Me!  Send Private Message   Edit Post
It's gotta be an alignment issue, or damaged pulley.
You should be able to get a dial indicator on the crank and alternator pulleys to check for wobble. You can usually eyeball the water pump pulley and see if it's out of round.
I suppose the water pump could also be a potential cause. Check to see if its bearing is tight.
I'd probably remove the PS and water pump pulley sandwich and make sure the stack is good to go. If one of the pulleys isn't seating correctly, or is bent, you'll have an issue. If there's corrosion of the face of the water pump mounting flange, that could cause problems with the pulley stack not seating flush.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3358 | From: SoCal | Member Since: 01/02/12 | IP:
(138.162.140.53) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1240314 posted 11/02/17 01:46 PM     Remind Me!  Send Private Message   Edit Post
Also, the rebuilt alternators sometimes have a different pulley than stock
Thom
1992 GVR-4 866/1000. Ready for all of the above.
1992 GVR-4 148/1000. Rescue
Posts: 761 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1240316 posted 11/02/17 03:23 PM     Remind Me!  Send Private Message   Edit Post
The crank is wobbling. Engine is coming out. What is weird, the car is running perfectly. I figured it out after the crank seal kept springing a leak. It was very obvious then. Oh well....Thanks for the help.
Edited by diambo4life (11/02/17 03:24 PM)
kumfasa
Galant VR-4 org Post #: 1240324 posted 11/02/17 08:18 PM     Remind Me!  Send Private Message   Edit Post
That escalated quickly!
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (58.28.212.87) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1240330 posted 11/03/17 11:06 AM     Remind Me!  Send Private Message   Edit Post
You can say that. I have a spare crank. Just hoping my pistons/rods are ok. Like I said, the car runs perfectly and if it was not throwing the belt, I would have never guessed this was happening.
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (68.97.83.160) | Report this post to a Moderator
Galant VR-4 org Post #: 1240331 posted 11/03/17 12:41 PM     Remind Me!  Send Private Message   Edit Post
Sure it is not just the crank pulley separating?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Defiant
136/1000
Galant VR-4 org Post #: 1240334 posted 11/03/17 01:58 PM     Remind Me!  Send Private Message   Edit Post
^^^I would check that first.
136/1000
Posts: 164 | From: Houston, TX | Member Since: 09/07/12 | IP: (204.58.246.49) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1240335 posted 11/03/17 03:07 PM     Remind Me!  Send Private Message   Edit Post
138/2000
Galant VR-4 org Post #: 1240336 posted 11/03/17 03:44 PM     Remind Me!  Send Private Message   Edit Post
fuuuuuck.... im amazed at the lack of horrific sounds. egg shaped crank ??
138/2000
Defiant
136/1000
Galant VR-4 org Post #: 1240343 posted 11/04/17 12:46 PM     Remind Me!  Send Private Message   Edit Post
daaaamn
136/1000
Eager Beaver
Galant VR-4 org Post #: 1240344 posted 11/04/17 03:43 PM     Remind Me!  Send Private Message   Edit Post
That was absurd. To the point of lack of noise, considering what happens when things are out by thousands, not by whole numbers ...
C53A 1 of the ~1500
Posts: 1556 | From: THE Ottawa | Member Since: 03/05/05 | IP: (135.23.119.187) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1240351 posted 11/04/17 05:16 PM     Remind Me!  Send Private Message   Edit Post
Yes, very absurd. Engine is on the stand. I will pull the pan tomorrow and see what lies within.
marvinmadman
136/1000
Galant VR-4 org Post #: 1240355 posted 11/04/17 06:03 PM     Remind Me!  Send Private Message   Edit Post
Crank twerked
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (24.32.60.245) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1240356 posted 11/04/17 06:48 PM     Remind Me!  Send Private Message   Edit Post
With the numbers that thing puts down I guess twisting a crank isn't out of the question.
138/2000
3 registered and 40 anonymous users are browsing this forum.
Generated in 0.216 seconds in which 0.193 seconds were spent on a total of 14 queries. Turbo powered.
