Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Transmission painting
Galant VR-4 org Post #: 1239222 posted 08/25/17 08:41 AM     Remind Me!  Send Private Message   Edit Post
Hey all you guys that have painted transmissions, what paint do you recommend? Engine paint? Rustoleum? Wheel paint?
Also, what color do you use, just basic silver or aluminum colored paint. Hoping to do this this weekend before putting it back in the car.
Thanks.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1239223 posted 08/25/17 09:09 AM     Remind Me!  Send Private Message   Edit Post
Nowadays, I use VHT FlameProof (not engine enamel) for almost everything under the hood that will see heat. I've tried other stuff, and nothing looks or holds up as well. The VHT FlameProof also covers awesome without primer or any of that shit. For prep, just make sure the trans is super clean. Any grease or oil will make for a crappy finish, but that goes for any paint. Simple Green, a brush and tons of scrubbing should do the job. For tough areas, use Simple Green and scrub with a dremel + small wire wheel. The VHT finish is more of a matte, which looks nicer (and more stock), IMO.
I've done my last few transmissions this way, as well as the one I recently did in my brother's car:
50/1000 before/after:
820/1000 before/after:
1837/2000 newly painted Shep trans and old trans after ~4k miles. Both VHT'd, and the old one still looks pretty good. Most of the fucked up spots on the old trans came from removal.
Posts: 3358 | From: SoCal | Member Since: 01/02/12 | IP: (207.255.187.121) | Report this post to a Moderator
Galant VR-4 org Post #: 1239224 posted 08/25/17 10:47 AM     Remind Me!  Send Private Message   Edit Post
Thanks Brett.
Couple more questions: One can enough for one trans? Silver color or available in aluminum color?
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1239225 posted 08/25/17 12:37 PM     Remind Me!  Send Private Message   Edit Post
One can could probably do the job. Like I said, it covers pretty well. 2 cans would be safe, with some left over for other bits. The shit never goes to waste in my garage, that's for sure.
I think I usually get the aluminum color, but it could be gray I suppose. The can doesn't actually say, only the cap indicates color. I'd go with the aluminum if they have it. Your local parts joint should stock it. It's not terribly cheap for spray paint, but it works awesome.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Galant VR-4 org Post #: 1239255 posted 08/28/17 07:51 AM     Remind Me!  Send Private Message   Edit Post
Over the weekend I found a partial can of the VHT Flat Aluminum paint, and I bought a can of Rustoleum high heat paint at the home center so I can compare. Unfortunately, did not get to the job this weekend, so no results yet.
89Mirageman
Galant VR-4 org Post #: 1239352 posted 09/02/17 09:52 AM     Remind Me!  Send Private Message   Edit Post
This is what I used a few months back. Think it was around $5 at Walmart.
Straight from the junkyard
After some elbow grease
One can was plenty
New yellow zinc case bolts really pop against the silver and brings it back to looking new again.
New reverse sensor from Rockauto and all the other bits hit lightly with gold.
94 Eagle Summit DL coupe
98 Mitsubishi Mirage DE sedan
15 Mitsubishi Mirage ES hatch
Edited by 89Mirageman (09/02/17 09:54 AM)
Posts: 2499 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (65.41.185.13) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1239355 posted 09/02/17 07:43 PM     Remind Me!  Send Private Message   Edit Post
That looks amazing. Prob the best painted and looking used transmission I've ever seen. Good work. I will do the same if I ever remove mine.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
2g MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Posts: 40 | From: Irvine CA | Member Since: 08/31/16 | IP: (166.170.14.82) | Report this post to a Moderator
COVR4355
355/1000
Galant VR-4 org Post #: 1239362 posted 09/03/17 05:54 PM     Remind Me!  Send Private Message   Edit Post
Good God Man that is impressive!
All from a $5 can from CrapMart???
Adding another to-do on my Winter list for the used transmission in the garage that will go in the Galant :P
Thank you and Well-done!
Posts: 25 | From: Grand Junction, CO | Member Since: 03/08/17 | IP: (65.128.2.114) | Report this post to a Moderator
Galant VR-4 org Post #: 1239372 posted 09/04/17 09:53 AM     Remind Me!  Send Private Message   Edit Post
Thanks for that Chris. I actually bought some of that paint too, and found some of the VHT in the garage, so I will try both of them. Your results are great. I don't think I will be doing the bolts right now though.
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
89Mirageman
Galant VR-4 org Post #: 1239439 posted 09/07/17 10:11 PM     Remind Me!  Send Private Message   Edit Post
Thanks guys! The bolts were around $45 I think. Probably barely notice them once its back in the car but I'll know they're there. Reminds me of my youth detailing models.
Galant VR-4 org Post #: 1240225 posted 10/29/17 05:17 PM     Remind Me!  Send Private Message   Edit Post
Well a few weeks ago I spent the time scrubbing, cleaning and painting my trans. Then continued on a did a couple more.
Used some of the VHT and the Rustoleum too. Will see how they hold up.
89Mirageman
Galant VR-4 org Post #: 1240273 posted 11/01/17 11:51 AM     Remind Me!  Send Private Message   Edit Post
They all look great.
Posts: 2499 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (65.41.184.115) | Report this post to a Moderator
3 registered and 49 anonymous users are browsing this forum.
Generated in 0.278 seconds in which 0.236 seconds were spent on a total of 14 queries. Turbo powered.
