Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Build Thread for 747/2000
Snook1345
Galant VR-4 org Post #: 1238841 posted 08/01/17 05:32 PM     Remind Me!  Send Private Message   Edit Post
Picked up 747 about a year and a half ago and since then have been hoarding parts to build it. (original sale post Link)
I finally have reached the point where i can begin to install everything that I have and see what breaks first.
As it sits, the car currently has 144k on the odometer and the motor is tired.
The trans seems okay and still shifts good, so i think i will just install a clutch for now.
Has Evo 8 Seats (courtesy of Mike Gombos), Evo III 16g, Turbo back, bc coilovers, xxrs, supra fuel pump
I started a few months ago by sourcing a 4 bolt rear end from Performance Partout.
Had new rear end installed, new axles, new bearings and bushings
Here is a parts list of what i have ready to go on the car
BBS LM F1 Championship Edition 17x9+35
werapped in Kuhmo Ecsta v720 tires
5 Lug Swap w all new bearings and seals
New F/R Rotors
New F/R Calipers/Pads
Extended Studs/Open End Lug Nuts
Threespeed Harness Bar
Fuel Pump Rewire
Aem Gauges (bought an extra D/side a pillar so i didnt have to hack my oem)
Momo Comp Steering Wheel
NRG Hub/ Quick Release
ETS FMIC
Cyclone Intake Manifold
CMP full turbo back
New Radiator w fans
ACT 2600
Crower Cams Stage 2 272/272
ARP L19 Head Stud Kit
Fidanza Adjustable Cam Gears
Topline Revised Lifters
Cometic StreetPro Gasket Kit
Gates Economy Timing Belt Kit
Manley Valve Spring & Retainer Kit
FIC 850cc Fuel Injectors
The motor is currently apart and about to go back together once a few more things arrive.
Still Need to get
DSM Link waiting to see if i can find an ETS intake
As i do stuff i will try to take pictures and update as much as possible
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (71.244.196.219) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1238844 posted 08/01/17 07:04 PM     Remind Me!  Send Private Message   Edit Post
Sounds like a nice little list, in for pictures and updates.
138/2000
Posts: 3451 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Rrohde84
Newbie
Galant VR-4 org Post #: 1238878 posted 08/03/17 10:31 AM     Remind Me!  Send Private Message   Edit Post
I see in the original for sale post that your car has thermal exhaust/muffler. do you plan on keeping it or any have information on it. I want to go with thermal exhaust on my car
Posts: 24 | From: Mundelein il | Member Since: 08/13/16 | IP: (204.58.204.13) | Report this post to a Moderator
faqinshiet
Member +
Galant VR-4 org Post #: 1238886 posted 08/03/17 04:03 PM     Remind Me!  Send Private Message   Edit Post
I loved this car need more pics!
90 GGSX-VR4 clone
Posts: 468 | From: Arlington, Va | Member Since: 12/06/11 | IP: (2601:140:8900:b6) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1238891 posted 08/03/17 07:10 PM     Remind Me!  Send Private Message   Edit Post
Damn, looks like you have a NICE list of parts. Saw the link, and you have JDM goodies. I think I hate you.
1099/2000 Summit white
"Do it once, Do it right."
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (152.51.48.1) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1239080 posted 08/15/17 05:10 PM     Remind Me!  Send Private Message   Edit Post
Just got word that the motor should be done this week so that is a win.
Today it rained it ass off here in MD but i got done what i could under my pop up tent.
My goal was to get the ABS Delete done and get ready to do the 5 Lug swap and install new brake parts.
Was going through my parts and "test" fit the BLOX extended studs that i ordered from JNZ.
they didn't fit at all, after looking on the website and emailing them, "some products may need to be spot welded" applied to me
which i found a little misleading because most of the stuff that they have on their site is pretty specific fitment for our cars.
Didn't sweat it, got the RMA and ordered ARP ones from extreme PSI, lesson learns.
I used the How to for ABS Removal on here link and skipped the stainless steel line brake line install because i had done that previously. After about ten minutes of messing around with all the 10mm wrenches I had, I went to lowes and bought a set of line wrenches<----you NEED this, at least the 10mm one.
Instead of pulling the ABS unit out and up, I took of the front fender liner and slid it out the bottom.
Im sure that installing hardlines from a 1g would be a serious PITA compared to the braided ones that i got in the JNZ kit.
The new lines and the new 1g prop valve made it not so bad.
When i ran the front passenger side line, I ended up taking out the wiper fluid holder and running the line in to mimic the factory line so i could keep it neat, was more work but looks good.
Only thing i have to do as far as ABS is concerned now is take the senors off, will take care of when i swap the hubs, and turn off the ABS light.
Hopefully have the hubs swapped by the end of the week, and then it is a waiting game until the LMs get here from Japan
Galant VR-4 org Post #: 1239093 posted 08/16/17 06:59 AM     Remind Me!  Send Private Message   Edit Post
Pull the ABS fuse from the box on the positive battery cable.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1239168 posted 08/20/17 11:27 PM     Remind Me!  Send Private Message   Edit Post
Ok so it has been a busy week with work for me but i have been trying to do a little bit everyday.
The 2 front hubs are swapped out with all new brake parts and extended studs on
I have the next two days off so getting the rears done should be no problem
The LMs got through customs and are finally in the states and motor is just about done =)
Goal by tuesday is to be able to drive the car again with the new brakes and 5 lug swap
If I get the rears done tomorrow and the hubs dont give me much trouble (doubtful) I am going to try to remove the cruise control tuesday.
Edited by Snook1345 (08/20/17 11:29 PM)
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (108.3.168.229) | Report this post to a Moderator
Hittman
my title is ghey
Galant VR-4 org Post #: 1239509 posted 09/13/17 10:59 PM     Remind Me!  Send Private Message   Edit Post
Ah my old hag! Glad to see you are putting time and effort into her, as she deserves it.
Forgy Sixfree
Essar Tewunty
Posts: 453 | From: Northern VA | Member Since: 09/11/09 | IP: (2600:1003:b10d:e) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1239537 posted 09/14/17 08:44 PM     Remind Me!  Send Private Message   Edit Post
Just a quick update:
got all of the gauges mounted where i want them and wires ran and connected, getting ready to pull the motor hopefully early next week (weather dependent)
had to throw the bbs on just to take a peak and see how it would look
Let me know what you guys think! hopefully get some more stuff cleaned up/done this weekend
COVR4355
355/1000
Galant VR-4 org Post #: 1239548 posted 09/15/17 08:37 AM     Remind Me!  Send Private Message   Edit Post
Looking NICE!!!
Love the build and the gold-BBS wheels are gorgeous
What are the specs on your tire + wheel setup?
Keep it coming!
Posts: 25 | From: Grand Junction, CO | Member Since: 03/08/17 | IP: (174.16.6.229) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1239556 posted 09/15/17 06:43 PM     Remind Me!  Send Private Message   Edit Post
thanks man
the wheels are 17x8 +35 in the front and 17x9 +35 in the back
all the same tires to keep the rolling diameter the same (so i could run stagger, wheels are hard to find, not patient enough to wait for a squared set in this good of shape)
tires are Kuhmo Ecsta v720 245/40/17
Snook1345
Galant VR-4 org Post #: 1239731 posted 09/27/17 08:35 PM     Remind Me!  Send Private Message   Edit Post
took the hood off and cleaned it and put on the ets fmic
Posts: 43 | From: Baltimore, md | Member Since: 04/18/16 | IP: (96.234.157.155) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1239999 posted 10/19/17 08:31 AM     Remind Me!  Send Private Message   Edit Post
almost
Galant VR-4 org Post #: 1240000 posted 10/19/17 10:08 AM     Remind Me!  Send Private Message   Edit Post
Nice furniture.
Snook1345
Galant VR-4 org Post #: 1240152 posted 10/26/17 01:12 AM     Remind Me!  Send Private Message   Edit Post
Motor is bolted in (well almost)
the rear mount that rock auto sent me was wayy to tall and after looking at a couple threads, i didnt even attempt to try to make it fit.
It really gets ridiculous because like a complete idiot, the night before I had tossed the old ones in a trashcan, that had mistakenly got taken out,
and the trash got collected that day. lol if you couldnt follow that, im an idiot and my stock mount is gone forever.
That being said, the other three mounts are in and tight and the motor is no longer is my living room.
Work week is pretty busy so I probably wont get another chance to work on the car until Mon/Tues so hopefully in a week or two I can try to crank it over.
Snook1345
Galant VR-4 org Post #: 1240804 posted 12/05/17 06:50 PM     Remind Me!  Send Private Message   Edit Post
damn! cant believe i started this process this long ago...i thought it would take 1 month maybe two and here i am rushing and rushing to get this thing done before it snows.
try to do a little bit everyday, with one of my buddies being a huge help on off days.
should be able to attempt the first start sun/mon depending on weather here
Snook1345
Galant VR-4 org Post #: 1241012 posted 12/18/17 07:40 AM     Remind Me!  Send Private Message   Edit Post
ALAS! yesterday in between the raindrops i chunked the galant onto a trailer and dropped it off at the shop.
Need to adjust the clutch pedal and go over the car on the lift one more time and then throw here on the rollers.
Hoping to make similar power to my Evo x, 350+ is the goal.
Will post video =)
Terrance362
needs moar imput
565/2000
Galant VR-4 org Post #: 1241076 posted 12/21/17 11:20 PM     Remind Me!  Send Private Message   Edit Post
Damn that looks good
565/2000
699/2000
Random 1gb FWD I bought
Posts: 328 | From: Winston-Salem, NC | Member Since: 08/14/06 | IP: (2606:a000:1018:4) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1241085 posted 12/22/17 11:04 PM     Remind Me!  Send Private Message   Edit Post
blown head gasket on the dyno
Snook1345
Galant VR-4 org Post #: 1241839 posted 03/03/18 08:55 AM     Remind Me!  Send Private Message   Edit Post
haven't posted in a while, car is up and running! I haven't gotten the chance to go on any long cruises yet but everything seems to be working well.
sourced an eterna grille and adjusted the coilovers so it wouldn't rub. Had to take the front to coilovers off the car to unseize them but overall happy with the way it looks.
Still have the install the harness bar and the wind deflectors that have been sitting around forever. Having an issue with the front drivers side window trim not seating in properly
and im thinking that i am just going to epoxy it.
got some touch up paint for a couple spots on the car and the doglegs, going to hit the grille with it too.
my goal for this year is to have it in some decent shows and take it to cars and coffee.
faqinshiet
Member +
Galant VR-4 org Post #: 1241848 posted 03/03/18 07:55 PM     Remind Me!  Send Private Message   Edit Post
Looks great!
90 GGSX-VR4 clone
Gombos
806/1000
Galant VR-4 org Post #: 1241862 posted 03/04/18 07:55 PM     Remind Me!  Send Private Message   Edit Post
Looks good man! Im glad she went to a good home! Im
Mike Gombos
806/1000 "Stella" 9.82 @ 143 E85, 608/407 on pump 93
747/2000 "Betty White" stock. Sold
Posts: 92 | From: irwin,pa | Member Since: 02/14/08 | IP: (2601:543:4000:94) | Report this post to a Moderator
Snook1345
Galant VR-4 org Post #: 1241867 posted 03/04/18 11:18 PM     Remind Me!  Send Private Message   Edit Post
thats fellas, hopefully see you sometime this year Mike, if you come to any events in MD or OC let me know man
faqinshiet
Member +
Galant VR-4 org Post #: 1241880 posted 03/05/18 07:13 PM     Remind Me!  Send Private Message   Edit Post
Well if you end up ongoing to cars and coffee post up here. Id like to check it out. Never made it to one when Brett was in this area.
90 GGSX-VR4 clone
Pages: 1 | 2
0 registered and 21 anonymous users are browsing this forum.
Generated in 0.553 seconds in which 0.494 seconds were spent on a total of 14 queries. Turbo powered.
