Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Front crank bearing/seal question
Vince
1212/2000
Galant VR-4 org Post #: 1238187 posted 06/27/17 03:02 AM     Remind Me!  Send Private Message   Edit Post
OK, so it looks like I have at least lost the front crank seal just from the amount of oil coming off the harmonic balancer.
But my question is this:
"Is loss of a front bearing common to this engine?"
My question/comments comes from recent events; I have had to repeatedly tighten the alternator to prevent squeal, but this is now something beyond simple belt stretch....
I admit I have yet to crack the service manual, and I hope a simple crank seal (are they simple?) is all I need, but the repeated tensioning has me worried that seals may not be my only problem.
Input please?
Domo Arigato,
Vince
Edited by Vince (06/27/17 03:03 AM)
Posts: 50 | From: Puget Sound, WA | Member Since: 01/31/15 | IP: (2603:3023:202:ef) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1238189 posted 06/27/17 06:17 AM     Remind Me!  Send Private Message   Edit Post
The main seal on the front case is fairly easy to swap out. You'll need to remove the timing belt, however, which may not be easy depending on your comfort level with the car.
Regarding the accessory belt coming loose, it's probably a crappy belt tensioner. Use a paint marker and mark the position of the alternator on the tensioner. After operating the car, see if the mark has moved to verify whether your tensioner is slipping or not. I highly doubt crankshaft play is to blame for your belt issues. If that were the case, it would certainly be apparent by how the engine sounds during operation.
I have some pics of swappimg out the main seal toward the end of the page: click
Posts: 3321 | From: SoCal | Member Since: 01/02/12 | IP: (2600:1003:b101:9) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1238193 posted 06/27/17 07:01 AM     Remind Me!  Send Private Message   Edit Post
I like to put a longer bolt where it goes through the tensioner block into the alternator and put a jam nut on the other side to hold that sucker solid.
I love my crazy mother!!!
Posts: 1539 | From: Manchester, NH | Member Since: 07/17/06 | IP: (173.14.186.153) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1238196 posted 06/27/17 08:52 AM     Remind Me!  Send Private Message   Edit Post
If any of that oil is getting on the belts, they will get soft and could stretch overtime making it necessary to re-tension them.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2742 | From: Savannah, GA | Member Since: 08/30/05 | IP: (69.245.80.109) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1238197 posted 06/27/17 09:01 AM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
+1
I do the exact same thing.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(214.4.253.121) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1238204 posted 06/27/17 11:38 AM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
I did this when my alt was in stock location as well. It's a good idea. The threads in the cast AL housing are pretty shitty, especially on rebuilt units.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3507 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.88.86) | Report this post to a Moderator
Vince
1212/2000
Galant VR-4 org Post #: 1238215 posted 06/27/17 07:55 PM     Remind Me!  Send Private Message   Edit Post
Thanks all,
Getting to the seal is no big deal except I have no garage. The car is parked in a storage unit, where I dont think they would like lots of oil on the clean concrete floor....
I've pulled the front end apart enough times to know how much I hate doing it, but can be pretty quick about it once I commit otherwise. Maybe I'll call about to a few shops for estimates....grrrrr...
The tensioner moving is not my first thought. It torques down pretty solid, and the amount of threads left on the adjuster is slowly going away. Probably just a bad belt.
Anyhow, thanks again
Vince
Resurrecting Nile Black 1212/2000
89Mirageman
Galant VR-4 org Post #: 1238216 posted 06/27/17 08:29 PM     Remind Me!  Send Private Message   Edit Post
Could also be cam seals, just running down behind the cover. Balance shafts still in, if not it could be where they plugged the front shaft on the case. Honestly though if the drive belts are oily you'll want to replace the timing belt no matter what the issue is.
94 Eagle Summit DL coupe
98 Mitsubishi Mirage DE sedan
15 Mitsubishi Mirage ES hatch
Posts: 2494 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (76.6.140.14) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1238249 posted 06/29/17 12:56 PM     Remind Me!  Send Private Message   Edit Post
I will add that the oil pump sprocket nut could have backed out, I just had this happen to me last month. I changed out the gasket and put blue loctite on it to hopefully not have it happen again.
Posts: 330 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
0 registered and 90 anonymous users are browsing this forum.
Generated in 0.231 seconds in which 0.208 seconds were spent on a total of 14 queries. Turbo powered.
