Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Evo BBS restoration
Evo BBS restoration
Nebraska
1099/2000
Galant VR-4 org Post #: 1236940 posted 05/05/17 10:59 AM     Remind Me!  Send Private Message   Edit Post
Hi, just wanted to share my wheels that I picked up last October. They were decent for the most part, as they had the occasional rock chips and skuffs. But the worst part by far was how bad they were curbed.
Wheels when I received them:
As most of the curb rash could be lightly sanded away and reshaped, one spot was really bad.
So at work one day when all the machines were running, I brought the wheel into our welding area and me and another tech started hammering the lip back into position and tig welding layer after layer. After we had a good amount metal built up all over the scar, an air grinder was used to straighten out the area as best as we could considering the outter lip was seriously displaced. I then used some sweet paint called Steel-It (not cheap) as a temporary coat to protect the area we worked on. I was impressed with how well it matched to the OEM color of these wheels.
Since Steel-It is awesome, and the powder coat I matched perfectly to the wheels was not an option because of cost ($350) the steel it won the bid at $20 a can. It has stainless flakes in it. I also plan to use the really nice clear coat that has the activator/hardener capsulated inside the can.
Here are some pics of a freshly painted Steel-It wheel w/out Clear next to one of my unpainted wheels. I like it!
Thanks for looking, I will keep adding as I do things with these wheels as they're probably one of most beautiful wheels to come out of Japan (edit: errrrr Germany.)
Garrett
Edited by Nebraska (05/07/17 11:58 AM)
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
faqinshiet
Member +
Galant VR-4 org Post #: 1236941 posted 05/05/17 11:02 AM     Remind Me!  Send Private Message   Edit Post
Nice work! Have the same wheels and they also need work done. Will have to try that out
90 GGSX-VR4 clone
Posts: 468 | From: Arlington, Va | Member Since: 12/06/11 | IP: (69.143.190.105) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1236942 posted 05/05/17 11:08 AM     Remind Me!  Send Private Message   Edit Post
Thanks man, yeah I found a good powder match for OEM. At prismatic powders they have a color called victory grey III. Order a free sample and if you like it, I'll sell you what I got a good price.
1099/2000 Summit white
"Do it once, Do it right."
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1236970 posted 05/07/17 10:55 AM     Remind Me!  Send Private Message   Edit Post
I love these wheels, and you did awesome work on the restoration. These look amazing on a VR-4. Now, let's see some pics of them installed!
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3346 | From: SoCal | Member Since: 01/02/12 | IP:
(207.255.187.121) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1236971 posted 05/07/17 11:47 AM     Remind Me!  Send Private Message   Edit Post
Thanks! Working on getting them installed, have a rebuilt subframe I need to maneuver in. These wheels are getting Dunlop direzza dz102's on them
OldHairyBastard
I take bottom on trannies
Galant VR-4 org Post #: 1236994 posted 05/08/17 03:42 PM     Remind Me!  Send Private Message   Edit Post
Looks good.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-200M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-82M
2017 VW Passat 1.8L Turbo-16M
Posts: 4495 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (162.197.249.69) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1237564 posted 05/28/17 11:34 PM     Remind Me!  Send Private Message   Edit Post
So I got the wheels completely done with used an awesome spray paint clear coat. It's $20 a can because it has an activator on the bottom that releases a hardener inside and creates a glass like surface. I love this stuff so much a used 5 cans on this part of the project. Of course had I know I would've needed so much I would have got some stuff for the old harbor freight purple gun. Pics on the car coming soon!
Nebraska
1099/2000
Galant VR-4 org Post #: 1237775 posted 06/06/17 10:25 AM     Remind Me!  Send Private Message   Edit Post
Now I'm in the process of getting the front ready. Should be a couple days
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1237800 posted 06/07/17 11:16 AM     Remind Me!  Send Private Message   Edit Post
Those look awesome. The Ralliart lugs are a really nice touch.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
4Grim
I deliver.
1948/2000
Galant VR-4 org Post #: 1237804 posted 06/07/17 11:32 AM     Remind Me!  Send Private Message   Edit Post
Nice work man!
91 GVR4 1948/2000
96 Galant 5sp DOHC 4G64T
2002 Montero Limited
1998 Montero SR (Winter package w/ adjustable suspension)
Posts: 2465 | From: Orlando FL | Member Since: 09/30/04 | IP: (192.234.90.30) | Report this post to a Moderator
89Mirageman
Galant VR-4 org Post #: 1237807 posted 06/07/17 12:38 PM     Remind Me!  Send Private Message   Edit Post
Very nice!
94 Eagle Summit DL coupe
98 Mitsubishi Mirage DE sedan
15 Mitsubishi Mirage ES hatch
Posts: 2498 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (76.6.140.14) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1237850 posted 06/08/17 08:42 PM     Remind Me!  Send Private Message   Edit Post
Thanks guys!
Full car pics coming soon!
Nebraska
1099/2000
Galant VR-4 org Post #: 1237907 posted 06/11/17 05:14 PM     Remind Me!  Send Private Message   Edit Post
Finally some full body pics. Need to raise the coilovers a little and get an alignment.
Rear end with new bushings/ball joints/bolts/bearings/seals/ebrake cable/and fluids.
New front calipers/bearings/seals/hubs/and ball joints.
All Abs components are removed and getting the actual abs module out soon. Any pointers for that would be appreciated.
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (66.87.142.77) | Report this post to a Moderator
faqinshiet
Member +
Galant VR-4 org Post #: 1237908 posted 06/11/17 06:28 PM     Remind Me!  Send Private Message   Edit Post
Looks great! Almost like mine
90 GGSX-VR4 clone
Posts: 468 | From: Arlington, Va | Member Since: 12/06/11 | IP: (2601:140:8900:b6) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1237910 posted 06/11/17 08:51 PM     Remind Me!  Send Private Message   Edit Post
Looks baller!
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Nebraska
1099/2000
Galant VR-4 org Post #: 1237912 posted 06/11/17 09:23 PM     Remind Me!  Send Private Message   Edit Post
Quoting faqinshiet:
I like yours as well!
And thanks GSTwithpsi
You guys think I get any positive camber in the rear? I have new alignment bolts and d2 coilovers...?
TheRedBaran3
Newbie
Galant VR-4 org Post #: 1238385 posted 07/06/17 10:55 AM     Remind Me!  Send Private Message   Edit Post
Looks awesome! I would love to pick a set of these up.
Posts: 6 | From: Buffalo, NY | Member Since: 09/04/15 | IP: (68.133.15.104) | Report this post to a Moderator
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1238452 posted 07/10/17 12:29 PM     Remind Me!  Send Private Message   Edit Post
That paint really came out nice!! I think that is the way to go versus powder coating. Powder coat is a nice durable finish, but the baking process requires you to expose the wheel to high heat for a while which can cause some mechanical property degredation. I know there are lower temp processes to avoid this but I will likely just paint wheels that need refinishing.
2003 Evo
2001 Prelude
2018 JK Wrangler
2002 Honda Odyssey
Posts: 1924 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (192.252.136.182) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1238463 posted 07/10/17 08:05 PM     Remind Me!  Send Private Message   Edit Post
Thanks guys. That paint is called Steel-It. P/n 100-2b. I found it online for $18-20 whereas other places it can be up $36.
The properties are pretty good, its durable and looks nice as it has small flakes of stainless in them. Ill post more pics tomorrow on my car.
Just a note: I let them outgas for a few days before putting the clear coat, which is also $20 A can, on them.
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (152.51.48.1) | Report this post to a Moderator
89Mirageman
Galant VR-4 org Post #: 1238480 posted 07/11/17 01:14 PM     Remind Me!  Send Private Message   Edit Post
Looks just right man, great job. And still way cheaper than a body shop. Also never thought about having to heat the wheel up for a long period with powder coating, makes sense.
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.253 seconds in which 0.22 seconds were spent on a total of 14 queries. Turbo powered.
